Our Maytag washer will not fill. It starts filling for five seconds and then shuts off. During the rinse cycle it fills correctly. How do I gain access to the fill level control. also I want to check the clear plastic tube that is attched to the level control. Do you think that the plastic tube is the problem? Maybe it has a hole in it or something??? Thanks
