Another Maytag Neptune won't spin
Model Number: MAH4000AWW Brand: Maytag Age: 1 - 5 years
Ser # 4433..... I followed the flow chart under "Won't spin" and it leads me to "Replace Machine Control Board". A tech I spoke w/ looked at that C Board and said he'd never seen one bad unless a certain resistor was blown (mine was good). He then said to jump between two wires, and if spinning was enabled, I should call Maytag for a free Motor Control Board kit and install it. However, the two wires he said to jump, RD 23 from the Door Lock/Spin Enable Switch and OR 40 (to Conn P2, #4, out-of-balance wire), both already had 118 VAC in them, so jumping was pointless. Here is all I know/did: When set in Spin cycle, Door Lock light comes on; wax motor extends properly, hits the Spin Enable Switch, and juice flows through it to Conn P3, #7; all 3 out-of-balance switches are normally closed and juice flows through them; all 7 of the used pins in Conn P3 have 118 VAC in them, even #1, marked "24 VDC" (that is a concern); no out-of-bal switch wires appear to be broken/loose, and since juice flows to Conn P2, #4, I gather that they are doing their thing. Does anyone have any ideas? Thanks. john
Related ModelsMaytag MAH4000AWW WASHER- HORIZONTAL AXIS Maytag MAH4000BWQ WASHER- HORIZONTAL AXIS Maytag MAH4000BWW WASHER- HORIZONTAL AXIS Maytag MAH5500AWQ WASHER- HORIZONTAL AXIS Maytag MAH5500AWW WASHER- HORIZONTAL AXIS Maytag MAH5500BWQ WASHER- HORIZONTAL AXIS Maytag MAH5500BWW WASHER- HORIZONTAL AXIS Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS Maytag MAH6500AWW WASHER- HORIZONTAL AXIS Maytag MAH6700AWM WASHER- HORIZONTAL AXIS Maytag MAH6700AWW WASHER- HORIZONTAL AXIS Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS Maytag MAH7500AWW WASHER- HORIZONTAL AXIS Admiral MAH7550AAW WASHER- HORIZONTAL AXIS Admiral MAH7550AGW WASHER- HORIZONTAL AXIS Maytag MAH8700AWM WASHER- HORIZONTAL AXIS Maytag MAH8700AWW WASHER- HORIZONTAL AXIS Maytag MAH9700AWM WASHER- HORIZONTAL AXIS Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS Maytag MAH9700AWW WASHER- HORIZONTAL AXIS Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner Maytag MAL1800AXM MISC / ACCESSORY Maytag MAL1800AXQ MISC / ACCESSORY Maytag MAL1800AXW MISC / ACCESSORY Maytag MAL2000AXQ MISC / ACCESSORY Maytag MAL2000AXW MISC / ACCESSORY Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner Maytag MAT10CSAAL MANUAL, PARTS (WASHER) Maytag MAT10CSAAW MANUAL, PARTS (WASHER) Maytag MAT10CSAGL MANUAL, PARTS (WASHER) Maytag MAT10CSAGW MANUAL, PARTS (WASHER) Maytag MAT10CSEGL MANUAL, PARTS (WASHER) Maytag MAT10CSEGW MANUAL, PARTS (WASHER) Maytag MAT10DAAAL MANUAL, PARTS (WASHER) Maytag MAT10DAAAW MANUAL, PARTS (WASHER) Maytag MAT10DAABL MANUAL, PARTS (WASHER) Maytag MAT10DAABW MANUAL, PARTS (WASHER) Maytag MAT10PDAAL MANUAL, PARTS (WASHER) Maytag MAT10PDAAW MANUAL, PARTS (WASHER) Maytag MAT10PDABL MANUAL, PARTS (WASHER) Maytag MAT10PDABW MANUAL, PARTS (WASHER) Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER) Maytag MAT10PSAAL MANUAL, PARTS (WASHER) Maytag MAT10PSAAW MANUAL, PARTS (WASHER) Maytag MAT10PSAGL MANUAL, PARTS (WASHER) Maytag MAT10PSAGW MANUAL, PARTS (WASHER) Maytag MAT11CSBKL MANUAL, PARTS (WASHER) Maytag MAT11MNAAW MANUAL, PARTS (WASHER) Maytag MAT11MNAGW MANUAL, PARTS (WASHER) Maytag MAT11MNEGW MANUAL, PARTS (WASHER) Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER) Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER) Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER) Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER) Maytag MAT12CSAAL MANUAL, PARTS (WASHER) Maytag MAT12CSAAQ MANUAL, PARTS (WASHER) Maytag MAT12CSAAW MANUAL, PARTS (WASHER) Maytag MAT12CSAGW MANUAL, PARTS (WASHER) Maytag MAT12CSAKL MANUAL, PARTS (WASHER) Maytag MAT12CSAKQ MANUAL, PARTS (WASHER) Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12CSEGW MANUAL, PARTS (WASHER) Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER) Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER) Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER) Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT12PDAAL MANUAL, PARTS (WASHER) Maytag MAT12PDAAW MANUAL, PARTS (WASHER) Maytag MAT12PDABL MANUAL, PARTS (WASHER) Maytag MAT12PDABW MANUAL, PARTS (WASHER) Maytag MAT12PDAGW MANUAL, PARTS (WASHER) Maytag MAT12PDBAL MANUAL, PARTS (WASHER) Maytag MAT12PDBAQ MANUAL, PARTS (WASHER) Maytag MAT12PDBAW MANUAL, PARTS (WASHER) Maytag MAT12PDBBL MANUAL, PARTS (WASHER) Maytag MAT12PDBBQ WASHER-TOP LOADING Maytag MAT12PDBBW MANUAL, PARTS (WASHER) Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER) Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER) Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER) Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PDEGW MANUAL, PARTS (WASHER) Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER) Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER) Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER) Maytag MAT12PDSAW MANUAL,PARTS (WASHER) Maytag MAT12PRAAW MANUAL, PARTS (WASHER) Maytag MAT12PRAEW MANUAL, PARTS (WASHER) Maytag MAT12PRBAW MANUAL, PARTS (WASHER) Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PRSAW MANUAL, PARTS (WASHER) Maytag MAT12PSAAW MANUAL, PARTS (WASHER) Maytag MAT12PSAGW MANUAL, PARTS (WASHER) Maytag MAT12PSBAW MANUAL, PARTS (WASHER) Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER) Maytag MAT13MNAAW MANUAL, PARTS (WASHER) Maytag MAT13MNAGW MANUAL, PARTS (WASHER) Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT13MNEGW MANUAL, PARTS (WASHER) Maytag MAT13PDAAW MANUAL, PARTS (WASHER) Maytag MAT13PDBAW MANUAL, PARTS (WASHER) Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER) Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER) Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER) Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
Reason: grammar fix
