Discuss
Hotpoint Washer Wont spin
 in
Washer Repair
My washer will fill, agitate, and drain but will not spin the clothes. They are sopping wet when I open
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Hotpoint Washer Wont spin
  #1 (permalink)
Old 04-22-2009, 08:36 PM
Junior Member
rtextreme2000 is on a distinguished road
Question Hotpoint Washer Wont spin
Model Number: VBXR1090   Brand: Hotpoint   Age: 1 - 5 years
My washer will fill, agitate, and drain but will not spin the clothes. They are sopping wet when I open the flip lid. It had left some standing water on the floor the other day I was told to replace the pressure switch and I did. It has not leaked again however, now it wont spin. It will start, fill, agitate like normal and it will drain but the drain pump keeps pumping after all the water is gone and it will not spin the water out of the clothing. It will keep trying to drain and eventually the timer will keep moving and shit the machine off. Clothes still soaking...... Any ideas? Any help would be greatly appreciated!
Scott
Ads By Google
Related Models
General Electric VBXR1090B0CC Washer
General Electric VBXR1090B0WW Washer
General Electric VBXR1090B2CC Washer
General Electric VBXR1090B2WW Washer
General Electric VBXR1090B3CC Washer
General Electric VBXR1090B3WW Washer
General Electric VBXR1090B4CC Washer
General Electric VBXR1090B4WW Washer
General Electric VBXR1090D0CC Washer
General Electric VBXR1090D0WW Washer
General Electric VBXR1090D1WW Washer
General Electric VBXR1090D2CC Washer
General Electric VBXR1090D2WW Washer
General Electric VBXR1090D3WW Washer
General Electric VBXR1090D4WW Washer
General Electric VBXR1090D5CC Washer
General Electric VBXR1090D5WW Washer
General Electric VBXR1090D6WW Washer
General Electric VBXR1090D7WW Washer
General Electric VBXR1090D8CC Washer
General Electric VBXR1090D8WW Washer
General Electric VBXR1090D9WW Washer
General Electric VBXR1090DACC Washer
General Electric VBXR1090DAWW Washer
General Electric VBXR1090DBCC Washer
General Electric VBXR1090DBWW Washer
General Electric VBXR1090DDCC Washer
General Electric VBXR1090DDWW Washer
General Electric VBXR2070T2AB Washer
General Electric VBXR2070T2WB Washer
General Electric VBXR2070T3AB Washer
General Electric VBXR2070T3WB Washer
General Electric VBXR2070T5AB Washer
General Electric VBXR2070T5WB Washer
General Electric VBXR2070T6AB Washer
General Electric VBXR2070T6WB Washer
General Electric VBXR2070T8AB Washer
General Electric VBXR2070T8WB Washer
General Electric VBXR2070TAAB Washer
General Electric VBXR2070TAWB Washer
General Electric VBXR2070V0AA Washer
General Electric VBXR2070V0WW Washer
General Electric VBXR2070V1AA Washer
General Electric VBXR2070V1WW Washer
Thermador VC-500
Gaggenau VC112-602
Gaggenau VC113-602
Gaggenau VC114-602
Gaggenau VC116-602
Gaggenau VC230-612
Gaggenau VC343-602
Gaggenau VC345-602
Gaggenau VC355-602
Thermador VCH-2
Thermador VCH-3
Thermador VCH-6
Thermador VCH-6A
Thermador VCH-7
Thermador VCH-7A
Thermador VCH-8
Thermador VCH-9
Amana VCH3 Ele Cartridge
Thermador VCH36
Amana VCH4 Ele Cartridge
Thermador VCH54
Thermador VCK-1
Thermador VCK-1A
Thermador VCK-300
Bosch VD030-000
Bosch VD030-010
Bosch VD030-099
Bosch VD040-000
Bosch VD040-010
Bosch VD040-099
Bosch VD050-010
Gaggenau VE112-612
Frigidaire VE21AW5 Tap(v1) / Electric Range
Amana VE3013 Washer - Top Loading
Frigidaire VE30AW5 Tap(v1) / Electric Range
Frigidaire VE30BW4 Tap(v1) / Electric Range
Frigidaire VE30CW4 Tap(v1) / Electric Range
Gaggenau VE313-613
Amana VE5013 Washer - Top Loading
Amana VEND-10.000 Commercial Microwaves
Amana VEND-10.A Commercial Microwaves
Amana VEND-10.B Commercial Microwaves
Amana VEND-10.C Commercial Microwaves
Amana VEND-10.F Commercial Microwaves
Amana VEND-10.G Commercial Microwaves
Amana VEND-10.H Commercial Microwaves
Amana VEND-10.J Commercial Microwaves
Amana VEND-7.003 Commercial Microwaves
Amana VEND-7.004 Commercial Microwaves
Amana VEND-7.005 Commercial Microwaves
Amana VEND-7.A Commercial Microwaves
Amana VEND-7.B Commercial Microwaves
Amana VEND-7D.001 Commercial Microwaves
Amana VEND-7D.A Commercial Microwaves
Amana VEND10 Commercial Microwaves
Amana VEND11 Commercial Microwaves
Amana VEND11B Commercial Microwaves
Hoover VER1360AGH Range - F/s Std Ele
Gaggenau VF112-610
Gaggenau VF230-610
Gaggenau VF332-610
Frigidaire VG21AW3 Tap(v1) / Gas Range
Frigidaire VG21AW3-23 Tap(v2) / Gas Range
Gaggenau VG223-812
Gaggenau VG230-811
Gaggenau VG231-211CA
Gaggenau VG232-212CA
Amana VG3019 Washer - Top Loading
Frigidaire VG30AW3 Tap(v1) / Gas Range
Frigidaire VG30AW3-23 Tap(v2) / Gas Range
Frigidaire VG30BW2 Tap(v1) / Gas Range
Frigidaire VG30BW2-23 Tap(v2) / Gas Range
Frigidaire VG30CW2 Tap(v1) / Gas Range
Frigidaire VG30CW2-23 Tap(v2) / Gas Range
Gaggenau VG330-811
  #2 (permalink)
Old 04-23-2009, 05:26 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It sounds like your water level switch is not recognizing that the water has drained out and that the timer can tell the machine to start spinning.
Check your water level switch again to make certain of the connections are good and that you have continuity in the wiring between the switch and the timer. Finally, check the plastic air tube that measures pressure and controls your water level.
You should find the problem somewhere in this process, and if not, a trip back to the place you purchased the water level switch may be in order for them to replace a defective part that you received.
Good luck, and let us know how this turns out.
__________________
  #3 (permalink)
Old 04-24-2009, 05:17 AM
Junior Member
Smile
Sid,
Thanks so much for your reply. I was doing a bunch of research online and found it could possibly be the lid switch. So I temporarily bypassed the switch and it works. So I hope it keeps on ticking. Have you heard of this?
Again thanks much Sid. I appreciate your help.
Scott
  #4 (permalink)
Old 04-24-2009, 06:00 AM
Senior Expert
APP Volunteer
Default
Glad you found the problem, but you should not operate the machine without a functioning lid switch. I strongly recommend that you replace the lid switch as soon as possible as it is there for a safety purpose, mainly to stop the spin when the lid is lifted and you or someone else is tempted to place your hands in the tub.
Hope it continues to work in the future
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer wont spin Tallen Washer Repair 4 12-08-2009 02:57 PM
Roper washer wont spin and wont empty jgirl14572 Washer Repair 2 10-11-2009 06:54 AM
washer wont spin Jamie2009 Washer Repair 0 08-18-2009 02:26 PM
Washer wont spin nickw Washer Repair 1 03-28-2009 06:01 AM
HotPoint washer won't agitate or spin after 2 or 3 seconds mfleij Washer Repair 1 12-03-2008 04:32 PM
