hi I have a stacked kenmore laundry center.my washer fills then it does nothing it doesn't agitate or spin what can the problem be.
The first thing you need to do is to check out the lid switch, this part here Part number: AP2108159
It is likely the cause of the problem, but if not you need to rule it out before going forward.
