Bought Bosch stackable washer/dryer. Standard hoses are 5' with hard plasticized fittings. We need 10' and Bosch does not make them. Want to buy second set and use a 3/4" x 3/4" brass adapter to string the two hoses together.
Will the brass adapter work, or will it stress the hard plastic fittings too much? Are there hard plastic adapters with the same dimension?
Appreciate any help. Bosch is very little help for these questions.
kgoldfisher
I'm not sure which adapters are you talking about. If you can post a pictures it might help better.
