Discuss
.36coupling install
 in
Washer Repair
when installing the coupling is the coupling flush with the moter shaft, auctually is it flush with both shafts? thanks
Appliance Repair Forum > Appliance Repair Help > Washer Repair » .36coupling install
  #1 (permalink)
Old 12-04-2007, 08:28 AM
herman herman is offline
Junior Member
herman is on a distinguished road
Question .36coupling install
Model Number: 11020802990   Brand: Kenmore   Age: 5 - 10 years
thanks herman
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-04-2007, 12:48 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Put the coupling on both shafts and use a small piece of would to press it on until it is flush. Then reassembly the unit. If either side is not on correctly, it will not go back together.
TechnicianBrian
  #3 (permalink)
Old 12-05-2007, 12:40 PM
Junior Member
Default
thank you Brian, I think the last one i put on Ihit it to hard and pushed it beyond the metal sleeve.
thanks again
herman
  #4 (permalink)
Old 12-05-2007, 05:44 PM
Junior Member
Default spin coulping
I installed the spin coulping, np probleum. I,m sure what i did last time is by useing a socket i pushed the plastic off the sleave, lesson learned
thank you
herman
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Install spray arm rshaffer Dishwasher Repair 2 09-20-2007 04:00 PM
How to install Microwave Terri2007 Microwave Repair 1 09-03-2007 01:36 PM
install condenser coils pattraveler Refrigerator & Freezer Repair 2 08-28-2007 11:03 PM
install condenser coils pattraveler Refrigerator & Freezer Repair 0 08-28-2007 12:28 PM
bOOT RE-INSTALL m1964 Washer Repair 0 08-05-2007 06:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
