kriegrelic
#1 Posted : Wednesday, April 22, 2009 11:08:51 AM(UTC)
kriegrelic
I have a Whirlpool washer (model LSC9355EQQ) that is leaking small amounts of water from the front underside when the machine is in the rinse cycle. I thought it might be loose hose connections at the pump but I checked and it doesn't seem to be that. I can't seem to trace where the leakage is coming from. Could the pump housing be cracked and need replacing? Do these usually go bad? Any suggestions?
Drags1998
#2 Posted : Wednesday, April 22, 2009 1:58:53 PM(UTC)
Drags1998
I would look at the back side of the pump,(where the motor drives it) If you see a streak around that area, replace the pump!!!!:)
Whirlpool washer leaking and won't fill with water (Washer Repair)
by christyhecht 6/16/2018 8:21:00 AM(UTC)
Whirlpool washer leaks from front - replaced pump... still leaks! (Washer Repair)
by metadog 2/17/2013 4:34:39 PM(UTC)
whirlpool washer leaks (Washer Repair)
by mdeagan 3/16/2012 1:54:39 PM(UTC)
Whirlpool Washer leaks (Washer Repair)
by Gern Blanston 1/24/2012 8:16:18 AM(UTC)
Whirlpool washer leaks at certain time of cycles (Washer Repair)
by Pegleg37 10/4/2011 10:16:55 AM(UTC)
Whirlpool Washer Leaking (Washer Repair)
by DSJordan 7/17/2011 4:59:48 PM(UTC)
Whirlpool washer leaks from front while filling (Washer Repair)
by bobandjayne 4/27/2011 12:08:00 PM(UTC)
Whirlpool washer leaks (Washer Repair)
by jstevens 9/19/2009 9:16:54 AM(UTC)
whirlpool washer leaking (Washer Repair)
by beverlyjean 5/18/2009 5:38:40 AM(UTC)
by modelshop8624 5/17/2009 7:28:08 PM(UTC)
Whirlpool washer leaking drain pump stuck to motor shaft, how to separate to replace? (Washer Repair)
by ennemm 5/3/2009 8:06:46 AM(UTC)
by pritch99 12/10/2008 10:51:19 AM(UTC)
by rookie01 10/30/2008 5:47:51 AM(UTC)
Whirlpool Washer Leaking when filling (Washer Repair)
by mrsrdstare 9/4/2008 8:44:27 AM(UTC)
by billmac77 8/5/2008 4:39:07 PM(UTC)
