| » No Drain on Samsung front load washer |
Model Number: WF448AAP Brand: Samsung Age: 1 - 5 years
Samsung front load washer--tries to drain on initial start up over & over. finally displays NO DRAIN error message. Sometimes I can get it to start by turning off power, waiting, then powering ON again. It seems like it gets stuck in the pre drain cycle before starting a new load, then can't get to the next part of the cycle to kick on. If I remove the pump filter (water gushes out) then it will start immediately.
I have checked for kinked or clogged lines and run AFFRESH washer cleaner tablets several times. Why won't it drain the last bit of water from the pump to let it start a new cycle? Is there a sensor or some type of water level indicator that keeps it trying to drain. Once I get it started it runs the whole cycle and cleans fine. Suggestions? Ads By Google Related Models |
| Display Modes | |
| GE Front Load Washer Won't Drain | scottbreen | Washer Repair | 35 | 01-27-2013 01:31 PM |
| Frigidaire Front Load Washer Won't Drain | Kater | Washer Repair | 2 | 05-31-2010 06:14 AM |
| Samsung Front load washer | Bootmaker | Washer Repair | 2 | 04-15-2010 06:27 AM |
| Samsung Front-Load Washer Safety Door Replacement | sbllrm1 | Washer Repair | 3 | 03-20-2010 05:40 PM |
| Samsung Top Load Washer won't drain sometimes | AllanN | Washer Repair | 0 | 01-02-2010 02:46 PM |
