| » slow spin and noisey in rinse cycle |
Model Number: LA6300XSNO Brand: Whirlpool Age: Less than 1 year
When machine goes into rinse cycle it does not seam to be spinning at full speed andis making a fast clicking metal to metal sound.
I opened machine and removed motor then put harness back on and turned it on, It spins and looks like it is going full speed but ther is a noise similair but not exactly the same as what I heard when in machine. The coupling is not broken and I can turn transmission by hand to a point but then it stops. Before I invenst in a motor I want to make sure transmission is good. Is it normal for it only to go to a certain point and stop when turning by hand. Once it stops if I turn the other wya it will go back to a point and stop. I was going to try to take out transmission but I cant get the spanner nut loose to get at it and dont want to damage anything. I am guessing there is a special tool for this although the manual says to use a hammer and screwdriver. machine is 20 years old and would buy new one if I had the funds but dont. Any input would be helpful thanks I have fixeed this machine before and have the original whirlpool repair manual for machine. Ads By Google Related Models |
I relize i have a bad motor but I am trying to figure out if it is the symptom a another problem hence I install a new motor and kaboom a week later.
I have the entire tranny clutch assembly removed but not broken down. when I turn the tranny clockwise it turns and spindle turns to a point then stops dead. when I turn it counter clockwise it continues to turn but spindle rotates in one direction and then the other, does that sound normal? |
| Display Modes | |
| Noisey Spin Cycle | Tony Noise | Washer Repair | 3 | 04-11-2011 07:51 AM |
| noisey spin cycle | Tony Noise | Washer Repair | 1 | 03-08-2011 07:01 PM |
| Jerky, Noisey, Slow Spin | nhguy261 | Washer Repair | 7 | 11-07-2010 03:44 AM |
| Jerky, Noisey, Slow Spin | nhguy261 | Dishwasher Repair | 0 | 11-03-2010 07:03 PM |
| Rinse cycle , no hyper spin just slow + no drain | buffnern | Washer Repair | 1 | 01-15-2010 03:06 PM |
