Discuss
Maytag MAV6300AWW won't spin
 in
Washer Repair
Hi, My Maytag MAV6300AWW won't spin, but will drain and go through the cycle. What I've tried, tipped up the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag MAV6300AWW won't spin
  #1 (permalink)
Old 09-25-2011, 08:35 AM
Junior Member
magnetb0y is on a distinguished road
Default Maytag MAV6300AWW won't spin
Brand: -brand-   Age: Less than 1 year
My Maytag MAV6300AWW won't spin, but will drain and go through the cycle. What I've tried, tipped up the machine, pulley spins and works and can turn both ways. When up top, tub is locked always and wont spin.
Please help.
Ads By Google
  #2 (permalink)
Old 09-26-2011, 06:31 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Try replacing the thrust bearing, this part here. Instructions are included
Part number: AP4009132
__________________
  #3 (permalink)
Old 09-26-2011, 06:46 PM
Junior Member
Default
Now that pulley spins when I tip up the machine during the spin cycle, does that matter? I dont get why the tub wont move.
  #4 (permalink)
Old 09-26-2011, 09:38 PM
Junior Member
Default
Is there any way to test that it is the thrust bearing before I buy it?
  #5 (permalink)
Old 09-27-2011, 05:04 AM
Senior Expert
APP Volunteer
Default
See if you can push upwards on the pulley while turning it and see if that engages the tub and it spins. I assume that when it is running the motor is operating freely and the pulley is turning but it won't spin.
__________________
  #6 (permalink)
Old 09-27-2011, 06:25 AM
Junior Member
Default
It worked! I hit it with a pair of pliers while running and it engaged, now it works but makes a loud screech when it stops so the thruster bearing is bad I assume that will fix all that?
  #7 (permalink)
Old 09-27-2011, 11:47 AM
Senior Expert
APP Volunteer
Default
The screeching when it stops is the sign of a brake problem, maybe caused by the impact of the pliers.
It may correct itself, try it for a little while.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 06:45 PM
Maytag A612S won't spin during spin cycles WQ2121 Washer Repair 3 07-18-2011 07:53 AM
Maytag Washer no spin at final spin and 3E keeps coming up chanchar Washer Repair 1 06-27-2011 06:02 PM
Maytag Neptune Super Stack will not spin while in spin cycle. Vohn Washer Repair 2 11-04-2010 08:30 AM
Maytag washer won't spin on spin cycle steve2zastrow Washer Repair 0 11-27-2009 09:04 AM
