| » Frigidaire won't agitate |
Model Number: fws747rfs1 Brand: Frigidaire Age: 5 - 10 years
I have a Frigidaire fws747rfs1 washer that has stopped agitating. It will fill, go into the agitate cycle, you can hear the motor going, but nothing from the agitator. Spin works fine. The agitator itself appears fine, no broken teeth, etc. If I try to spin the agitator by hand cw, moves a few inches and then stops.I found the service manual and did a few tests. If I spin the pulley ccw, it spins the basket. If I spin the pulley cw, the pulley will spin, its not locked up or anything, but the agitator shaft doesn't move (but I don't know if it should move or not, the flowchart in the manual just asks if the pulley itself spins or not). I checked the voltage drop at the lid switch, it was around 5-8 VAC, which I believe is normal (flow chart said 120 or 0 was bad). I then tried to take off the basket, but that failed. I got the 5 bolts off, but no matter how hard both my wife and I pulled at it, banged it with a mallet, etc. it would not budge.
My thinking right now is that a gear has broken a tooth or stripped out in the transmission that engages the agitator shaft. That is just speculation with an educated guess. If that is the case, I would imagine either I have to replace the transmission or try and rebuild it. If that is the case, any suggestions on getting the basked off besides trying to removed the entire basked, tub, transmission assembly as a whole? Thanks to all who reply. Ads By Google Related Models |
I think you are right, operate it with the front cover off and you should be able to tell if the motor is turning but the transmission is not turning the agitator.
There are no parts that I know of for a rebuild and given the age of the machine I think you are better off with a new one.
__________________
| Display Modes | |
| Frigidaire washer won't agitate | wickedmessenger | Washer Repair | 0 | 08-10-2010 08:32 AM |
| Frigidaire Washer wont agitate | CheapMoney | Washer Repair | 0 | 12-31-2009 02:42 PM |
| Frigidaire won`t agitate | tomspaulding | Washer Repair | 1 | 12-20-2009 01:49 PM |
| Frigidaire Washer Doesn't Agitate properly | B_WILSON | Washer Repair | 1 | 02-19-2009 04:11 PM |
| Frigidaire Will Not Agitate | Corbie | Washer Repair | 7 | 12-18-2007 06:15 AM |
