| » Belt replacement |
You are going to have to remove the motor, then take the pump off. Also make sure you get the right belt as there may be several for this model depending upon which motor you have. You will need both your model number and your serial number.
Also see if you can determine why the belt burned up, and make sure you repair that problem.
__________________
| Display Modes | |
| belt replacement | herman | Washer Repair | 1 | 11-29-2010 07:13 PM |
| Belt replacement | HVN | Dryer Repair | 0 | 05-13-2010 03:08 PM |
| Belt replacement | Marion13 | Dryer Repair | 0 | 11-14-2009 12:36 PM |
| belt replacement | pblserrano | Dryer Repair | 1 | 06-05-2009 03:52 PM |
| belt replacement | seanog | Washer Repair | 1 | 08-20-2008 02:59 PM |
