| » spins 3 cycles one way, 3 cycles the other way, then will not spin after that |
Model Number: gbvh6260 Brand: GE Age: 5 - 10 years
Ge Front Load Washer spins only when first turned on. About 3 revolutions one way, then the other. It will not spin after that. One other interesting note, I can not enter service mode with delay start delay start. I removed the control panel and checked all connections, removed them all one at a time, and then replaced them.....
Any new suggestions or instructions would help. Thank you in advance Jim Ads By Google Related Models |
From everything I could read up on this unit, I'm leaning towards the control unit also. However, I will try the inverter suggestion also and will let you know about the ongoing struggle with this machine and it's attitude.. Thanks...
| Display Modes | |
| Washer Spins, Clothes Too Wet End of Cycles | wsg | Washer Repair | 2 | 09-04-2010 10:23 AM |
| GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points | nickf829 | Washer Repair | 1 | 12-20-2009 04:43 PM |
| wont spin after all cycles | spinning44 | Washer Repair | 1 | 11-27-2009 10:09 AM |
| kenmore washer only spins on two of three cycles | herman | Washer Repair | 7 | 11-19-2009 05:04 PM |
| Won't spin between cycles | dcavers | Washer Repair | 6 | 08-23-2008 07:06 PM |
