Discuss
Bosch Axxis WFR2460 Brush Replacement
 in
Washer Repair
My washer stopped spinning (no rotation of the drum whatsoever), and I think from other posts it is the motor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Bosch Axxis WFR2460 Brush Replacement
  #1 (permalink)
Old 12-03-2007, 10:05 AM
mowind mowind is offline
Junior Member
mowind is on a distinguished road
Default Bosch Axxis WFR2460 Brush Replacement
Model Number: WFR2460 UC/01   Brand: Bosch   Age: 5 - 10 years
My washer stopped spinning (no rotation of the drum whatsoever), and I think from other posts it is the motor brushes. I've stripped it down to the motor being ready to remove (disconnected motor mounting bolts and the wiring harness), but the motor won't budge off the mounting posts. Two questions:
1) Should I remove the motor to access the brushes, and if so, what's the trick, and
2) How do I remove and reinstall the brushes themselves - the flat piece with the soldered connector needs to come off, but I don't see how that is supposed to work.
FYI, I've been using a mirror to examine the brush mount assemblies...
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 12:50 PM
Junior Member
Default Update
I was able to remove the motor (pried gently with screwdriver at rear mounting posts) so that's solved, but still don't see how to remove the carbon brushes.
  #3 (permalink)
Old 02-10-2008, 08:12 AM
tlandonjr tlandonjr is offline
Junior Member
tlandonjr is on a distinguished road
Default
mowind, did replacing the motor brushes fix your no spin problem? My washer has the same issue.
Thanks,
Thomas
  #4 (permalink)
Old 02-10-2008, 02:43 PM
Junior Member
Default
Yes, it was the brushes. In fact, I had to order them so I cleaned up the old ones which were quite worn down (probably 2/3 gone) and reinstalled them and the washer has been going strong since. I have an appointment in my Treo's calendar to install the new brushes in December '08 (assuming it is still going then). btw, I've owned the washer for about 5 years. Now I have a new issue that I haven't been able to research yet, the fabric softener dispenser seems plugged because when the wash cycle finishes the dispenser is full of water. I also have the matching dryer and it is not taking it's loads to complete dry on the automatic setting.
Hope this helps...
  #5 (permalink)
Old 02-10-2008, 05:48 PM
Junior Member
Default
Thanks for the reply. I actually tapped on the brushes and the washer now spins. I've placed some new brushes on order and will just replace them when they come in.
Replies to your other issues (should probably go in a new thread).
Fabric softener: I had this same issue a few years ago and it reoccurs every couple of years. You are correct, it is related to a clog. To fix the problem you need to remove the detergent tray (pull the tray out, then using your thumb press on the blue plastic "button" and pull the tray completely out). Remove the blue plastic thing. Residue that forms the clog is usually in both the blue plastic piece and the detergent tray. Pipe cleaners and cotton swaps work well for cleaning both pieces. The tray should be cleaned at two points, where the fabric softener pours out and the tube on which the blue plastic piece attaches
Dryer: I haven't had this issue. However, I would be interested to know what the problem is and the final resolution. Below is another link that has good info too, you might check there as well.
http://www.fixya.com/support/p117053-bosch_axxis_wta_3510_electric_dryer
Regards,
Thomas
  #6 (permalink)
Old 03-20-2008, 02:40 PM
WILLIAM CASTILLO WILLIAM CASTILLO is offline
Junior Member
WILLIAM CASTILLO is on a distinguished road
Exclamation Bosch Washer Wfl2060 Uc/22
WOULD LIKE TO KNOW ..HOW TO SEPARATE THE FRONT AND REAR DRUM...TO INSTALL THE BEARING KIT.
  #7 (permalink)
Old 03-20-2008, 03:36 PM
Junior Member
Default
William,
I have never replaced the drum bearings so I can really help you much. However, here is a link to a diagram of the drum assembly. Maybe it will be helpful?
Regards,
Thomas
http://www.appliancepartspros.com/se...yjf7pta4jh.gif
  #8 (permalink)
Old 03-31-2008, 07:04 PM
petereit petereit is offline
Junior Member
petereit is on a distinguished road
Default Wash the lint filter
Even if you remove lint from the lint filter after every load, eventually, the fine holes in the filter will completely clog from dirt and super-fine lint. Soak the filter in a solution of hot water and detergent and scrub clean with a brush or wash cloth. When completely clean, the fabric in the filter should resemble brand new pure white women's nylons.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Axxis dryer problem Chipper Dryer Repair 2 04-01-2008 06:43 PM
Bosch On/Off Button&Switch Replacement dkh Dishwasher Repair 3 12-13-2007 09:01 PM
Bosch dishwasher Elise Dishwasher Repair 9 11-13-2007 04:46 PM
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 06:04 PM
Bosch dishwasher Elise Dishwasher Repair 2 08-13-2007 07:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
