Discuss
Whrilpool Spin Problem
 in
Washer Repair
This has probably been answered many times here, but there are so many threads to sift through... I apologize if
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whrilpool Spin Problem
  #1 (permalink)
Old 04-19-2009, 06:54 PM
Junior Member
RESinNC is on a distinguished road
Default Whrilpool Spin Problem
Model Number: LSR7233BW2   Brand: Whirlpool   Age: 5 - 10 years
This has probably been answered many times here, but there are so many threads to sift through... I apologize if it's a repeat.
I have a Whirlpool washer and I'm having spin cycle problems. The machine agitates fine, but with large loads, it doesn't spin. It will spin ok with a small load. It spins, but starts very slowly with a medium size load.
The motor seems to be running fine in all cases. The lid switch is working fine. I do seem to have a little dead spot on the timer, but that's not in the neighborhood of where the spin cycle starts. The water will drain, so I don't think I have an issue there.
I'm no expert in washer repair, but this sounds like the symptoms of a clutch slipping. Anyone have any thoughts?
Ads By Google
Related Models
Whirlpool LSR7233BW2
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0
Whirlpool LSR7233DQ1
Whirlpool LSR7233DW0
Whirlpool LSR7233DZ0
Whirlpool LSR7233DZ1
Whirlpool LSR7233EQ0
Whirlpool LSR7233EQ1
Whirlpool LSR7233EW0
Whirlpool LSR7233EZ0
Whirlpool LSR7233EZ1
Whirlpool LSR7233HQ0
Whirlpool LSR7233HZ0
Whirlpool LSR7300PQ0 Automatic Washer
Whirlpool LSR7300PQ1 Automatic Washer
Whirlpool LSR7300PQ2 Automatic Washer
Whirlpool LSR7333PQ0 Automatic Washer
Whirlpool LSR7333PQ1 Automatic Washer
Whirlpool LSR7333PQ3 Automatic Washer
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 Automatic Washer
Whirlpool LSR8010PQ1 Automatic Washer
Whirlpool LSR8010PQ2 Automatic Washer
Whirlpool LSR8010PT0 Automatic Washer
Whirlpool LSR8010PT1 Automatic Washer
Whirlpool LSR8010PT2 Automatic Washer
Whirlpool LSR8133HQ0
Whirlpool LSR8133HZ0
Whirlpool LSR8200EQ0
Whirlpool LSR8200EZ0
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 Automatic Washer
Whirlpool LSR9434PQ1 Automatic Washer
Whirlpool LSR9434PQ3 Automatic Washer
Whirlpool LSR9434PQ4 Automatic Washer
Whirlpool LSR9434PT0 Automatic Washer
Whirlpool LSR9434PT1 Automatic Washer
Whirlpool LSR9434PT3 Automatic Washer
Whirlpool LSR9434PT4 Automatic Washer
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0
Whirlpool LSS9244EZ0
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
  #2 (permalink)
Old 04-20-2009, 06:33 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The clutch is the first place to start. Remove the transmission and do the test described in the sticky at the start of this section about brakes and direct drive washers.
Let us know how it turns out, and if it is not the clutch we will see what else we can come up with.
__________________
  #3 (permalink)
Old 04-20-2009, 06:34 PM
Junior Member
Default
Ok, I checked the coupling. It's worn, but not broken. I'll replace that just for fun since I have it torn apart, but I don't think it's the problem. The clutch doesn't look excessively worn, no oil, very small amount of dust inside. The brake shoes don't seem to be hanging either. They seem to disengage completely when turning the cam.
So, I guess I'm not seeing anything obvious. One thing i did note is that the pump is a little hard to turn. The water drains though.
Any ideas? Could it be the clutch if I'm not seeing anything obvious there?
  #4 (permalink)
Old 04-20-2009, 06:50 PM
Junior Member
Default
Ok, let me add another bit of information. Holding the outside of the clutch housing, I can twist the lining inside the housing a bit if I twist reasonably hard. Should I be able to move this by hand at all?
Again on the pump - is it normally a little hard to turn it?
I really appreaciate any help anyone can offer!!
  #5 (permalink)
Old 04-21-2009, 05:37 PM
Senior Expert
APP Volunteer
Default
Ok, thanks for the new information.
Possibility 1: The pump is partially jammed and this is slowing the motor so that it cannot turn fast enough to spin clothes with a heavy load. The test would be to put it back together with the pump off, and a heavy load and see if the problem is solved. If so, replace the pump.
Possibility 2: If the pump is not hindering the motor, and the motor is turning ok and the transmission is working and the brakes are not dragging then it has to be the clutch. In this case a new clutch kit should fix you up.
One final check you might make is the drive block but it does not seem likely.
Let us know what you do and how it turns out.
Good luck!
__________________
  #6 (permalink)
Old 04-21-2009, 06:40 PM
Junior Member
Default
I went ahead and ordered a new clutch assembly and coupling. I'm most suspicious of the clutch, I guess, so I figure I'll go ahead and replace it while I have the whole thing torn apart. Time to replace the coupling before it fails, too. If I'm still having issues, I'll try the pump next. That's easy enough to replace without a major tear down.
I took a look at the drive block and it looks good.
I'll let you know how I made out in a couple days. Thanks for the advice!
  #7 (permalink)
Old 04-21-2009, 06:55 PM
Senior Expert
APP Volunteer
Default
Sounds like the right thing to do, let us know what happens
__________________
  #8 (permalink)
Old 04-23-2009, 07:56 PM
Junior Member
Default
Everything is back together with no problems - no floods, no flames. I ran a couple heavy loads and it spins like new!
  #9 (permalink)
Old 04-24-2009, 06:02 AM
Senior Expert
APP Volunteer
Default
Great, thanks for updating us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whrilpool SC8900EX only one burner lights ScottB Oven Repair (including Ranges and Cooktops) 3 11-26-2009 02:17 PM
Whrilpool freezer leak Marylou Refrigerator & Freezer Repair 1 05-26-2009 07:58 AM
Whrilpool ice-maker won't stop making ice Dennis101 Dryer Repair 0 03-26-2009 08:58 AM
whrilpool dryer kelleyracing69 Dryer Repair 1 12-22-2008 06:54 PM
Whrilpool Extension Hose Torwadeo Washer Repair 2 10-15-2008 10:07 PM
