| » Will not spin during spin cycle |
Model Number: LNC6747A71 Brand: Admiral Age: 5 - 10 years
I have an Admiral washer that will not spin...
When I set it to normal wash and it reaches the spin cycle, it does not spin. There is no loud noise... The timer is still ticking.... All cycles work fine... it agitates, drains, fills, etc.... just doesn't spin... I can set it to other spin cycles on the dial and they work just fine (spin cycle for permanent press, extra rinse, delicate) Any help would be appreciated..... Last edited by jack_flash_ji : 12-03-2007 at 12:00 PM. Reason: added more info |
Most likely the problem with your washer is a bad timer.
The model number you posted does not come up and I'm not able to give you the right part number for the new timer. Please, verify the model number or find the part number from the old timer and post it. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
had admiral washer that had similar problem. had leak in hose from tub to pump. leaking water on floor & not draining. when it would finally drain, would not spin. service guy said had leak in hose from tub to pump. when water leaked onto floor also leaked onto hose. the hose would slip & not work properly. when hose replaced (10.00) worked fine in draining tub & spinning. check that out....
| Display Modes | |
| noisy spin cycle | looz98 | Washer Repair | 1 | 04-08-2008 12:23 AM |
| Spin Cycle will not work | Apache6434 | Washer Repair | 4 | 11-28-2007 04:55 AM |
| noisy spin cycle | eddieb | Washer Repair | 1 | 11-23-2007 07:43 PM |
| Spin Cycle | bottomman | Washer Repair | 1 | 11-16-2007 11:13 AM |
| Washer will not spin on spin cycle | bellboy | Washer Repair | 0 | 11-11-2007 09:16 AM |
