Discuss
Will not spin during spin cycle
 in
Washer Repair
I have an Admiral washer that will not spin... When I set it to normal wash and it reaches the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Will not spin during spin cycle
  #1 (permalink)
Old 12-03-2007, 08:11 AM
jack_flash_ji jack_flash_ji is offline
Junior Member
jack_flash_ji is on a distinguished road
Question Will not spin during spin cycle
Model Number: LNC6747A71   Brand: Admiral   Age: 5 - 10 years
When I set it to normal wash and it reaches the spin cycle, it does not spin. There is no loud noise... The timer is still ticking.... All cycles work fine... it agitates, drains, fills, etc.... just doesn't spin...
I can set it to other spin cycles on the dial and they work just fine
(spin cycle for permanent press, extra rinse, delicate)
Any help would be appreciated.....
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 11:16 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your washer is a bad timer.
The model number you posted does not come up and I'm not able to give you the right part number for the new timer.
Please, verify the model number or find the part number from the old timer and post it.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-05-2007, 08:21 AM
Junior Member
Default
The model number is correct....
Will have to pull apart the washing machine tonight to get the number off the timer.
  #4 (permalink)
Old 01-01-2008, 07:53 AM
bamadadof2 bamadadof2 is offline
Junior Member
bamadadof2 is on a distinguished road
Lightbulb belt?
had admiral washer that had similar problem. had leak in hose from tub to pump. leaking water on floor & not draining. when it would finally drain, would not spin. service guy said had leak in hose from tub to pump. when water leaked onto floor also leaked onto hose. the hose would slip & not work properly. when hose replaced (10.00) worked fine in draining tub & spinning. check that out....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisy spin cycle looz98 Washer Repair 1 04-08-2008 12:23 AM
Spin Cycle will not work Apache6434 Washer Repair 4 11-28-2007 04:55 AM
noisy spin cycle eddieb Washer Repair 1 11-23-2007 07:43 PM
Spin Cycle bottomman Washer Repair 1 11-16-2007 11:13 AM
Washer will not spin on spin cycle bellboy Washer Repair 0 11-11-2007 09:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
