| » Estate washer won't spin or drain, agitate cycle grinds to halt |
Model Number: taws800jq1 Brand: Estate Age: 5 - 10 years
Fills with water, starts agitating but wihtin a few minutes, agitator starts to slow down somewhat grinding to a halt with a lot of clicking sounds and a hum in the dial selector/timer for a few seconds. I've detected a faint electrical odor. If I don't touch the dial to turn it off, after about 5 minutes, the agitator starts again, runs for a minute, starts to bog down with the same bit of grinding noise and clicking and then it stops.
It never makes it to the spin or drain cycle. And also, when I turn the dial to choose spin or rinse there is no response. I've removed the pump and checked it for blockage and it looks ok. Removed the coupler pieces and they are in tact. Tested the lid switch for continuity and it's ok. What's next? How do I check the timer switch. Is it more likely the clutch assembly, transmission, or brake or agitator? I'd like to avoid taking apart these pieces since it seems more involved. Are there other parts I haven't mentioned that need to be troubleshooted? Thanks. Mark Ads By Google Related Models |
Here's a video of the washer grinding to a halt: Estate washer problem won't spin or drain, agitate cycle grinds to halt - YouTube
It's a direct drive motor. no belt. no flooding. thanks.
Remove the pump and motor and turn the tranny coupler counterclockwise until the tranny engages. If you feel roughness while turning the coupler, you have a bad tranny, rather rare though.
__________________
| Display Modes | |
| Kenmore 80 Spin Cycle Grinds, wont drain | losositos | Washer Repair | 1 | 09-07-2012 12:15 PM |
| Whirlpool Estate washer runs but doesn't agitate or drain | torqhead | Washer Repair | 4 | 11-22-2010 02:14 PM |
| Washer will not agitate, spin out in rinse cycle or drain | AngieM | Washer Repair | 9 | 09-26-2009 06:55 PM |
| my estate washer only fills up but wont agitate rinse or spin | redbacks12 | Washer Repair | 0 | 08-03-2008 09:15 PM |
