Discuss
admiral washer
 in
Washer Repair
Update on last post. Took the front off washer. The noise seems to be coming from the inner tub rubbing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » admiral washer
  #1 (permalink)
Old 12-02-2007, 06:03 PM
margsain margsain is offline
Junior Member
margsain is on a distinguished road
Default admiral washer
Model Number: AAV7000AWW   Brand: Admiral   Age: 1 - 5 years
Update on last post. Took the front off washer. The noise seems to be coming from the inner tub rubbing as it agitates against the out tub. Have tried spraying with silicon all moving points and seals and nothing seems to stop the noise unless either the load is light or you pick up clothes out of water so they are not agitated to the bottom of tub. The heavier the load the noisier it gets because of the weight. It is a 3.3 tub which should handle a good size load. It did not start this problem until the warranty was up.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 03:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
One of possibilities there is a foreign object(s) between the inner and the outer tubs. You probably have to remove the inner tub to test it.
It could be a loosen screws mounted the inner tub.
Also possible damage to the central bearing.
You can find complete instructions how to fix your washer in the service manual.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
admiral washer margsain Washer Repair 3 09-05-2008 01:35 PM
capacity plus admiral dryer broken_dryer_forthuachuca Dryer Repair 0 11-19-2007 06:43 PM
how do i replace a belt on an Admiral Dryer pookie Dryer Repair 3 10-11-2007 05:07 AM
Admiral Refrigerator yazooms37342 Refrigerator & Freezer Repair 1 08-10-2007 12:40 PM
admiral capacity plus jcwilson Washer Repair 1 07-30-2007 06:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
