Discuss
estate washer fills then stops
 in
Washer Repair
need help. used this site before and it was AWESOME. MY washer fills then stops. i jumped the lid assembly
Appliance Repair Forum > Appliance Repair Help > Washer Repair » estate washer fills then stops
  #1 (permalink)
Old 09-19-2011, 08:05 PM
Junior Member
sandyn is on a distinguished road
Default estate washer fills then stops
Model Number: tws700rq3   Brand: Whirlpool   Age: 1 - 5 years
need help. used this site before and it was AWESOME. MY washer fills then stops. i jumped the lid assembly so it will fill. looked at motor assembly and notice a singed area on the white plastic wire "assembly" and then noticed that the blue wire coming from the motor was not connected to the rest of the housing. i think it may have 'fried'. is there a way to check the motor ( i have a multimeter but dont know which wires to test) I placed the blue wire back onto the metal "male" and then tried it after putting the white housing back on. no change still fills but nothing else. you can hear a clicking up near the control panel. i think its the motor but am afreid to buy before I'm sure thats the problem because theyre expensive---$150 i think. any help you could give would be great
Ads By Google
Related Models
Frigidaire TWX233RBD0 Tap(v4) / 27 " Washer
Frigidaire TWX233RBD1 Tap(v1) / 27 " Washer
Frigidaire TWX233RBD2 Tap(v1) / Top Load Washer
Frigidaire TWX233RBD3 Tap(v1) / Washer
Frigidaire TWX233RBW0 Tap(v3) / 27 " Washer
Frigidaire TWX233RBW1 Tap(v2) / 27 " Washer
Frigidaire TWX233RBW2 Tap(v2) / Top Load Washer
Frigidaire TWX233RBW3 Tap(v2) / Washer
Frigidaire TWX233REW1 Frg(v0) / Washer
Frigidaire TWX645RBD0 Tap(v2) / 27 " Washer
Frigidaire TWX645RBD2 Tap(v3) / Top Load Washer
Frigidaire TWX645RBD4 Tap(v1) / Washer
Frigidaire TWX645RBW0 Tap(v1) / 27 " Washer
Frigidaire TWX645RBW1 Tap(v3) / 27 " Washer
Frigidaire TWX645RBW2 Tap(v4) / Top Load Washer
Frigidaire TWX645RBW3 Tap(v0) / Washer
Frigidaire TWX645RBW4 Tap(v2) / Washer
Amana TX18J Ref - Top Mount
Amana TX18K Ref - Top Mount
Amana TX18K2 Ref - Top Mount
Amana TX18M Ref - Top Mount
Amana TX18MB Ref - Top Mount
Amana TX18N Ref - Top Mount
Amana TX18NB Ref - Top Mount
Amana TX18Q2L Ref - Top Mount
Amana TX18Q2W Ref - Top Mount
Amana TX18QB2L Ref - Top Mount
Amana TX18QB2W Ref - Top Mount
Amana TX18QBG Ref - Top Mount
Amana TX18QBL Ref - Top Mount
Amana TX18QBW Ref - Top Mount
Amana TX18QG Ref - Top Mount
Amana TX18QL Ref - Top Mount
Amana TX18QW Ref - Top Mount
Amana TX18R2L Ref - Top Mount
Amana TX18R2W Ref - Top Mount
Amana TX18RL Ref - Top Mount
Amana TX18RW Ref - Top Mount
Amana TX18VC Ref - Top Mount
Amana TX18VE Ref - Top Mount
Amana TX18VL Ref - Top Mount
Amana TX18VW Ref - Top Mount
Amana TX19R2E Ref - Top Mount
Amana TX19R2L Ref - Top Mount
Amana TX19R2W Ref - Top Mount
Amana TX19R3E Ref - Top Mount
Amana TX19R3L Ref - Top Mount
Amana TX19R3W Ref - Top Mount
Amana TX19RE Ref - Top Mount
Amana TX19RL Ref - Top Mount
Amana TX19RW Ref - Top Mount
Amana TX19S3E Ref - Top Mount
Amana TX19S3L Ref - Top Mount
Amana TX19S3W Ref - Top Mount
Amana TX19V2E Ref - Top Mount
Amana TX19V2L Ref - Top Mount
Amana TX19V2W Ref - Top Mount
Amana TX20J Ref - Top Mount
Amana TX20K Ref - Top Mount
Amana TX20M Ref - Top Mount
Amana TX20MB Ref - Top Mount
Amana TX20N Ref - Top Mount
Amana TX20NB Ref - Top Mount
Amana TX20QBG Ref - Top Mount
Amana TX20QBL Ref - Top Mount
Amana TX20QBW Ref - Top Mount
Amana TX20QG Ref - Top Mount
Amana TX20QL Ref - Top Mount
Amana TX20QW Ref - Top Mount
Amana TX21A3E Ref - Top Mount
Amana TX21A3L Ref - Top Mount
Amana TX21A3W Ref - Top Mount
Amana TX21R2E Ref - Top Mount
  #2 (permalink)
Old 09-21-2011, 05:32 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I don't think it is the motor, the motors are really reliable, more likely someting in the wiring. Move the timer dial around and see if you can get it to agitate or spin or some other setting.
If nothing, see if you can replace the wire harness from the control panel to the motor. That may fix things.
If you buy from this site and the parts do not fix the problem you can return them, see the returns policy for details and conditons, of which there are few.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Estate washer fills and then stops all functions wvwoodchuck48 Washer Repair 3 04-29-2011 06:45 AM
Washer Fills, Then Stops yogivic54 Washer Repair 5 04-11-2011 06:57 PM
washer fills then stops julie larson Washer Repair 3 01-07-2009 03:55 AM
whirlpool estate washer only fills jakeman Washer Repair 4 08-16-2008 03:43 AM
my estate washer only fills up but wont agitate rinse or spin redbacks12 Washer Repair 0 08-03-2008 09:15 PM
