Discuss
Can't move my washer!
 in
Washer Repair
The outside shell of the washer has become unattached to the body of the washer on the right side (facing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Can't move my washer!
  #1 (permalink)
Old 04-17-2009, 01:27 PM
Croftfam Croftfam is offline
Junior Member
Croftfam is on a distinguished road
Question Can't move my washer!
Model Number: 82983120   Brand: Kenmore   Age: 5 - 10 years
The outside shell of the washer has become unattached to the body of the washer on the right side (facing machine). When I go to move the washer, the metal casing of the washer moves. It looks like the side needs to be lifted to fit into a track at the bottom, however, I can't find a way to lift the side high enough in order to set it back on the track at the bottom. Is there an easier method to return this side to it's proper position?
Related Models
Magic Chef 82FA-1 Surface Unit - Gas
Magic Chef 82FA-12 Surface Unit - Gas
Magic Chef 82FA-12K Surface Unit - Gas
Magic Chef 82FA-1K Surface Unit - Gas
Magic Chef 82FG-1K Surface Unit - Gas
Magic Chef 82FK-1
Magic Chef 82FK-1K Surface Unit - Gas
Magic Chef 82FN-1 Surface Unit - Gas
Magic Chef 82FN-1K Surface Unit - Gas
Magic Chef 82FS-1 Surface Unit - Gas
Magic Chef 82FS-12 Surface Unit - Gas
Magic Chef 82FS-12K Surface Unit - Gas
Magic Chef 82FS-1K Surface Unit - Gas
Magic Chef 82FY-1 Surface Unit - Gas
Magic Chef 82FY-1K
Magic Chef 82HA-1 Surface Unit - Gas
Magic Chef 82HA-12 Surface Unit - Gas
Magic Chef 82HA-1K Surface Unit - Gas
Magic Chef 82HA-2K Surface Unit - Gas
Magic Chef 82HN-1 Surface Unit - Gas
Magic Chef 82HN-1K Surface Unit - Gas
Magic Chef 82HN-2K Surface Unit - Gas
Magic Chef 82HS-1
Magic Chef 82HS-1K
Magic Chef 82HS-2K Surface Unit - Gas
Magic Chef 82HW-1K
Magic Chef 82HY-1K
Magic Chef 82JA-2K Surface Unit - Gas
Magic Chef 82JK-2K
Magic Chef 82JN-2K Surface Unit - Gas
Magic Chef 82JS-2K
Magic Chef 82LA-1 Surface Unit - Gas
Magic Chef 82LA-2K Surface Unit - Gas
Magic Chef 82LK-2K Surface Unit - Gas
Magic Chef 82LK-3K Surface Unit - Gas
Magic Chef 82LN-1 Surface Unit - Gas
Magic Chef 82LN-2K Surface Unit - Gas
Magic Chef 82LN-3K Surface Unit - Gas
Magic Chef 82LS-1 Surface Unit - Gas
Magic Chef 82LS-2K Surface Unit - Gas
Magic Chef 82LW-2K Surface Unit - Gas
Magic Chef 8311PA Surface Unit - Gas
Magic Chef 8311PS Surface Unit - Gas
Magic Chef 8311PW Surface Unit - Gas
Magic Chef 8311TA Surface Unit - Gas
Magic Chef 8311TS Surface Unit - Gas
Magic Chef 8311TW Surface Unit - Gas
Magic Chef 8320PA Surface Unit - Gas
Magic Chef 8320PB
Magic Chef 8320PS Surface Unit - Gas
Magic Chef 8320PW Surface Unit - Gas
Magic Chef 8320TA Surface Unit - Gas
Magic Chef 8320TS Surface Unit - Gas
Magic Chef 8320TW Surface Unit - Gas
Magic Chef 8321PA Surface Unit - Gas
Magic Chef 8321PB Surface Unit - Gas
Magic Chef 8321PS Surface Unit - Gas
Magic Chef 8321PW Surface Unit - Gas
Magic Chef 8321TA Surface Unit - Gas
Magic Chef 8321TB Surface Unit - Gas
Magic Chef 8321TS Surface Unit - Gas
Magic Chef 8321TW Surface Unit - Gas
Whirlpool 8340NFSBS00
Magic Chef 8341VB Surface Unit - Gas
Magic Chef 8341VD Surface Unit - Gas
Magic Chef 8341VS Surface Unit - Gas
Magic Chef 8341VV Surface Unit - Gas
Magic Chef 8351VB Surface Unit - Gas
Magic Chef 8351VD Surface Unit - Gas
Magic Chef 8351VQ Surface Unit - Gas
Magic Chef 8351VS Surface Unit - Gas
Magic Chef 8351VV Surface Unit - Gas
Magic Chef 8361RB Surface Unit - Gas
Magic Chef 8361RV Surface Unit - Gas
Magic Chef 8361RW Surface Unit - Gas
Magic Chef 83EA-1 Surface Unit - Gas
Magic Chef 83EA-1G Surface Unit - Gas
Magic Chef 83EA-1GK Surface Unit - Gas
Magic Chef 83EA-1K Surface Unit - Gas
Magic Chef 83EB-1G Surface Unit - Gas
Magic Chef 83EB-1GK Surface Unit - Gas
Magic Chef 83EN-1 Surface Unit - Gas
Magic Chef 83EN-1G Surface Unit - Gas
Magic Chef 83EN-1GK Surface Unit - Gas
Magic Chef 83EN-1K Surface Unit - Gas
Magic Chef 83EP-1GK Surface Unit - Gas
Magic Chef 83ES-1 Surface Unit - Gas
Magic Chef 83ES-1G Surface Unit - Gas
Magic Chef 83ES-1GK Surface Unit - Gas
Magic Chef 83ES-1K Surface Unit - Gas
Magic Chef 83ET-1GK
Magic Chef 83EY-1 Surface Unit - Gas
Magic Chef 83EY-1GK
Magic Chef 83FA-1 Surface Unit - Gas
Magic Chef 83FA-1G Surface Unit - Gas
Magic Chef 83FA-1GK Surface Unit - Gas
Magic Chef 83FA-1K Surface Unit - Gas
Magic Chef 83FG-1K Surface Unit - Gas
Magic Chef 83FK-1 Surface Unit - Gas
Magic Chef 83FN-1 Surface Unit - Gas
Magic Chef 83FN-1G Surface Unit - Gas
Magic Chef 83FN-1GK Surface Unit - Gas
Magic Chef 83FN-1K Surface Unit - Gas
Magic Chef 83FS-1 Surface Unit - Gas
Magic Chef 83FS-1G Surface Unit - Gas
Magic Chef 83FS-1GK Surface Unit - Gas
Magic Chef 83FS-1K Surface Unit - Gas
Magic Chef 83FY-1GK Surface Unit - Gas
Magic Chef 83HA-1 Surface Unit - Gas
Magic Chef 83HA-1G Surface Unit - Gas
Magic Chef 83HA-1GK Surface Unit - Gas
Magic Chef 83HA-1K Surface Unit - Gas
Magic Chef 83HN-1G
Magic Chef 83HN-1GK
Magic Chef 83HN-1K
Magic Chef 83HS-1G
Magic Chef 83HS-1GK
Magic Chef 83HS-1K
Magic Chef 83JA-1GK Surface Unit - Gas
Magic Chef 83JK-1GK Surface Unit - Gas
  #2 (permalink)
Old 04-17-2009, 02:30 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
This is not a difficult fix, and not expensive but the problem should not have happened.
Either you had this machine worked on, and the service tech did not put it back together right, or you purchased this machine used and someone else worked on it and did not get it back together. You are either missing the clip that holds the cabinet on the right side, or it has popped out. When you get the cabinet off look for it, but it may not be there.
The part you need is the following.
Part Details - WHIRLPOOL Clip, part number: 62780
What you need to do is to remove the console, unhook the lid switch, remove the cabinet, reset it, reinstall the clips and then reinstall the console. This video will show you how it is done. It will take some patience to get the cabinet back in right, just be sure and hold it at a 45 degree angle, make certain the front lip is under the front frame and drop it into the slots. It make take several tries. Look at the left side to see how the plastic spline goes in correctly.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Good luck and let us know how it works out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
RCA washer Agitator doesn't move during wash circle nini Washer Repair 5 03-30-2009 02:17 PM
Washer Won't Move To Next Cycle BoydJSmith Washer Repair 0 11-23-2008 10:31 AM
Kenmore Washer Dial won't move rrmiles Washer Repair 0 01-22-2008 12:25 PM
Washer Thumping after move lmcclure1220 Washer Repair 1 01-21-2008 12:01 PM
Washer fills but does not move or drain RedScott Washer Repair 3 10-27-2007 05:00 PM
