Discuss
Checking Agitator
 in
Washer Repair
Having a problem with my Washer , the agitator seems to spin too freely. I wanted to check this out
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Checking Agitator
  #1 (permalink)
Old 04-17-2009, 10:33 AM
Junior Member
bonieckij is on a distinguished road
Default Checking Agitator
Brand: Kitchen Aid   Age: 5 - 10 years
I wanted to check this out by removing , how it the top removed the
agitator (where you put in fabric softener) ...tried to screw off . Just
seems to turn continuiously. Is there any trick or is mine stripped or something (may be part of the problem) ..wanted to try tightening things up. Did not want to break off the top .
  #2 (permalink)
Old 04-17-2009, 02:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Without the complete model number it is just a guessing. So I'm guessing your washer is one of the direct drive washers family and the problem is a worn out agitator dogs. In such case you can use the information from one of our previous posts: Top agitator slipping
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-03-2009, 07:02 AM
Junior Member
Default Agitator repair
I have a kitchen aid washer madel KAWE570BWH0. Having problems with the clothing rapping around the agitator , getting jammed. I ordered the agitator repair kit thinking it may be the agitor dogs were worn. I also noticed that spacer thrust seemed to be different than the one I took off the machine, new one had these tiny clips on the slots (was not sure if the needed to be clipped off?) ...anyway I did the replacement, all seemed to fit in properly, but the problem seems to continue.
There is a clip under the agitor ...do not see an obvious problem wit with it ...not sure what that is supposed to look like . Any help would be appreciated
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Checking thermal cut-off Black Dryer Repair 2 12-30-2009 12:14 PM
Checking Thermostats!!! addygirl Dryer Repair 1 11-30-2009 04:05 PM
Checking Continuity jdphoto Dryer Repair 1 04-14-2009 12:40 PM
Checking compressor oil bb1710 Refrigerator & Freezer Repair 4 09-12-2008 07:19 AM
New guy, checking in Freiheit General Talk 1 03-04-2008 11:53 PM
