Discuss
GE washer fills and spins at same time
 in
Washer Repair
This is going to be a long post. I have read many of the other posts and have gone through
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer fills and spins at same time
  #1 (permalink)
Old 09-19-2011, 09:44 AM
Junior Member
Tim56 is on a distinguished road
Default GE washer fills and spins at same time
Model Number: WHRE5550K2WW   Brand: GE   Age: 1 - 5 years
This is going to be a long post. I have read many of the other posts and have gone through the tests suggested. He are the specs: GE Hyrowave w/infusor. Model WHRE5550K2WW manuf 01/2009 and purchased 1/2010. Motor #175D5106G057. PROBLEM: When filling it starts to fill then after 5-10 seconds it starts to spin fast and still fill. LED lights on panel start with fill, then to wash then back to fill. Spinning eventually stops and sometimes it goes no further. Other times it continues on with the cycles and other times it gets to the rinse, goes through that but then back to wash (according to the LED lights).This doesn't stop, as though it's stuck in a loop. All this time the machine is making the normal clunks etc that the shifter is supposed to make. Both the agitator and drum move at the same time..which makes me believe the shifter coil is bad. Basically that's it. It doesn't appear to do all these things on all cycles though-maybe because different cycles have different modes it goes through. Now the Tests: MOTOR LED-green-blinks normal for both washer off (1 sec continual) and washer on (.5 sec continual). No error codes. In SERVICE MODE: All positions are ok. No error codes-(positions 2-4). Positions 5-11, functions are all ok. Pressure switch ok both full and empty. LID SWITCH: Has continuity when closed, none when open. RESETTING: Tried, but no go. MODE SHIFTER COIL: C7 reads 67 Ohms not 98. FUSE: OK-neutral tab to white/red wire-got continuity. C4 CONNECTOR: (blue,far right). Pin 5 to 3 -12 VDC. Pin 5 to 4 -12 VDC. C CONNECTOR: (white, far left). White/red wire to red/black-120V. Also the large pulley does turn free. AND I already replaced the control board suggested by another forum. Can the motor still be bad if the LED is showing normal or is it because the shifter coil is only reading 67 ohms, not 98? Is that a motor problem...not getting enough juice to the coil? Please don't tell me both or the sledge hammer is coming out !
Ads By Google
Related Models
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLH1 Frg(v5) / 27 " Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Frigidaire WISCLW0 Frg(v3) / 27 " Washer
Frigidaire WISCLW1 Frg(v4) / 27 " Washer
Frigidaire WISCLW2 Frg(v1) / 27 " Washer
Frigidaire WISCW2 Frg(v4) / Washer
Frigidaire WISCW3 Frg(v4) / Washer
Frigidaire WISCW5 Frg(v4) / Top Loading Washer
Frigidaire WISCW6 Frg(v3) / Top Load Washer
Frigidaire WISDH3 Frg(v6) / Top Load Washer
Frigidaire WISDL2 Frg(v21) / Top Loading Washer
Frigidaire WISDL3 Frg(v5) / Top Load Washer
Frigidaire WISDLH1 Frg(v8) / 27 " Washer
Frigidaire WISDLL0 Frg(v6) / 27 " Washer
Frigidaire WISDLL1 Frg(v9) / 27 " Washer
Frigidaire WISDLW0 Frg(v5) / 27 " Washer
Frigidaire WISDLW1 Frg(v7) / 27 " Washer
Frigidaire WISDW2 Frg(v22) / Top Loading Washer
Frigidaire WISDW3 Frg(v4) / Top Load Washer
General Electric WISQ416AT5WW Washer
General Electric WISQ416AT6WW Washer
General Electric WISQ416AT7WW Washer
General Electric WISQ416AT8WW Washer
General Electric WISQ416ATAWW Washer
General Electric WISQ416BT5WW Washer
General Electric WISQ416BT6WW Washer
General Electric WISQ416BT7WW Washer
General Electric WISQ416BT8WW Washer
General Electric WISQ416BTAWW Washer
General Electric WISQ416CT5WW Washer
General Electric WISQ416CT6WW Washer
General Electric WISQ416CT7WW Washer
General Electric WISQ416CT8WW Washer
General Electric WISQ416CTAWW Washer
General Electric WISQ416DT5WW Washer
General Electric WISQ416DT6WW Washer
General Electric WISQ416DT7WW Washer
General Electric WISQ416DT8WW Washer
General Electric WISQ416DTAWW Washer
General Electric WISQ416FTAWW Washer
General Electric WISQ416JT5AA Washer
General Electric WISQ416JT6AA Washer
General Electric WISQ416JT7AA Washer
General Electric WISQ416JT8AA Washer
General Electric WISQ416JTAAA Washer
General Electric WISR106CT5WW Washer
General Electric WISR106DGBWW Washer
General Electric WISR106DT5WW Washer
General Electric WISR106DT8WW Washer
General Electric WISR106DTAWW Washer
General Electric WISR106DTBWW Washer
General Electric WISR106HT8WW Washer
General Electric WISR106HTAWW Washer
General Electric WISR208JT5AA Washer
General Electric WISR208JT6AA Washer
General Electric WISR208JT8AA Washer
General Electric WISR208JTAAA Washer
General Electric WISR309CT5WW Washer
General Electric WISR309CT6WW Washer
General Electric WISR309CT8WW Washer
General Electric WISR309CTAWW Washer
General Electric WISR309DGBWW Washer
General Electric WISR309DT5WW Washer
General Electric WISR309DT6WW Washer
General Electric WISR309DT8WW Washer
General Electric WISR309DTAWW Washer
General Electric WISR309DTBWW Washer
General Electric WISR409DGBWW Washer
General Electric WIST208JT5WW Washer
General Electric WIST208JT6WW Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills, spins but won't agitate Scanman Washer Repair 1 04-05-2011 05:39 PM
my washer agitates and spins at the same time arturo goche Washer Repair 1 01-26-2011 09:02 AM
Washer Agitates and spins at the same time kimlee Washer Repair 0 05-12-2010 08:50 PM
Washer fills then spins Mike schrack Washer Repair 1 01-15-2009 05:27 PM
washer spins and washes at the same time chadeus Washer Repair 1 11-09-2008 06:42 AM
