| » inglis top loader, water leak around sides |
This may be a problem, or it may not be. Hopefully not but lets see.
Use a level to make certain the machine is level across the front. Make sure the floor around the machine is dry, then run a full load and watch the machine to see if it leaks again. It could be that you had a highly unbalanced load which resulted in the water sloshing out of the machine, and you want to eliminate this as a cause before proceeding and getting an expensive service call. If it continues to show a water leak, please post back with your model number and we will give you some ideas of how to check it out.
__________________
thanks for your reply, sidfink43.
it has not happened in a while, so i'm assuming it was only out of balance. i never did level it as it seems it doesn't really need it. we've started to load the machine a different way which i'm assuming solved it. |
| Display Modes | |
| Adjust water volume in front loader | kbinafrica | Washer Repair | 1 | 01-23-2010 10:17 PM |
| Adjust water volume in front loader | kbinafrica | Washer Repair | 1 | 01-22-2010 11:51 AM |
| water leak in front of refrigerator when using water dispenser | RichardCh | Refrigerator & Freezer Repair | 0 | 08-10-2009 10:29 AM |
| water leak in back from water line | TRUSTART | Refrigerator & Freezer Repair | 1 | 04-05-2009 07:01 AM |
| front loader fills with water | TRACIE18 | Washer Repair | 0 | 12-30-2008 09:30 AM |
