Discuss
WASHER - tub won't agetate or spin
 in
Washer Repair
Washer (Front Loader) has no problem filling or draining, but it will not agetate. I removed the belt from the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » WASHER - tub won't agetate or spin
  #1 (permalink)
Old 04-16-2009, 11:34 PM
Junior Member
eddieandthewasher is on a distinguished road
Cool WASHER - tub won't agetate or spin
Model Number: GLTF1670as0   Brand: Frigidaire   Age: 1 - 5 years
Washer (Front Loader) has no problem filling or draining, but it will not agetate. I removed the belt from the motor, the motor will turn a little or it will try to turn, as soon as you touch the shaft it stops. Not enough POWER to the shaft to keep it spinning. Motor won't engage. There is power to the shaft but not enough to make it spin, which happens in the wash cycle or spin cycle. Tried new motor, same thing. At first I thought it was caused by a broken shock, after replacing both still no change
Ads By Google
Related Models
Frigidaire GLTF1670AS0 Frtld Wshr - Frigidaire Gal
Frigidaire GLTF1670AS1 Frigidaire/washer
Frigidaire GLTF2070CS0 Frigidaire/washer
Frigidaire GLTF2070DS0 Frigidaire/washer
Frigidaire GLTF2940EE0 Frigidaire/washer
Frigidaire GLTF2940ES0 Frigidaire/washer
Frigidaire GLTF2940ES1 Frigidaire/washer
Frigidaire GLTF2940ES2 Frigidaire/washer
Frigidaire GLTF2940ES3 Frigidaire/washer
Frigidaire GLTF2940FE0 Frigidaire/washer
Frigidaire GLTF2940FS0 Frigidaire/washer
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Whirlpool GLWA6900W0
Whirlpool GLWA6900W1
Whirlpool GLWA6900W2
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Whirlpool GLXA6900W0
Whirlpool GLXA6900W1
Whirlpool GLXA6900W2
Whirlpool GLXA6900W3
Gaggenau GM104-710
Gaggenau GM104-714
International GM1110PRW Range - F/s Std Gas
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
International GM3110MPAW Range - F/s Std Gas
International GM3110MXAW Range - F/s Std Gas
International GM3110PRAM Range - F/s Std Gas
International GM3110PRWM Range - F/s Std Gas
International GM31113WAM Range - F/s Std Gas
International GM31113WAV Range - F/s Std Gas
International GM3111GXAW Range - F/s Std Gas
International GM3111SXAW Range - F/s Std Gas
International GM31211XAW Range - F/s Std Gas
International GM3167WUA Range - F/s Std Gas
International GM3167WUV Range - F/s Std Gas
International GM3210MXAW Range - F/s Cont Clean Gas
International GM3211GXAA Range - F/s Cont Clean Gas
International GM3211GXAW Range - F/s Cont Clean Gas
International GM3211SXAA Range - F/s Cont Clean Gas
International GM3211SXAW Range - F/s Cont Clean Gas
International GM3216WRWM Range - F/s Cont Clean Gas
International GM32211XAW Range - F/s Cont Clean Gas
International GM3267WUAM Range - F/s Cont Clean Gas
International GM3267WUWM Range - F/s Cont Clean Gas
International GM3267XUA Range - F/s Cont Clean Gas
International GM3267XUAM Range - F/s Cont Clean Gas
International GM3267XUW Range - F/s Cont Clean Gas
International GM3267XUWM Range - F/s Cont Clean Gas
Gaggenau GM335-760
Maytag GM3468XUW-X Range - S/c F/s Gas
Maytag GM3468XUWX Range - S/c F/s Gas
International GM3510PRW Range - F/s Std Ele
International GM3531WUV Range - S/c F/s Ele
International GM3531WUW Range - S/c F/s Ele
International GM3631XUA Range - F/s Std Ele
International GM3631XUW Range - F/s Std Ele
International GM3862XUW Range - S/c F/s Ele
International GM3868XUA Range - S/c F/s Ele
International GM3868XUW Range - S/c F/s Ele
Maytag GM4151WTA Range - F/s Std Gas
Maytag GM4151WTW Range - F/s Std Gas
Maytag GM4251WTA Range - F/s Cont Clean Gas
Maytag GM4251WTW Range - F/s Cont Clean Gas
Whirlpool GM8131XEB0
Whirlpool GM8131XEB1
Whirlpool GM8131XEQ0
Whirlpool GM8131XEQ1
Whirlpool GM8155XJB0
Whirlpool GM8155XJB1 Convection Microwave Oven
Whirlpool GM8155XJB2 Convection Microwave Oven
Whirlpool GM8155XJQ0
Whirlpool GM8155XJQ1 Convection Microwave Oven
Whirlpool GM8155XJQ2 Convection Microwave Oven
Whirlpool GM8155XJT0
Whirlpool GM8155XJT1 Convection Microwave Oven
Whirlpool GM8155XJT2 Convection Microwave Oven
Gaggenau GM915-710 UC/06 (FD 7710-7912)
Gaggenau GM915-710 UC/11 (FD 7912-8003)
Gaggenau GM915-710 UC/12 (FD 8003-)
Gaggenau GM926-710 UC/06 (FD 7710-7912)
Gaggenau GM926-710 UC/11 (FD 7912-8003)
  #2 (permalink)
Old 04-17-2009, 04:50 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Can you clarify your post. Does it not agitate, agitate slowly and the same question about the sping, does it not spin or spin too slowly.
Since you have replaced the motor the next suspect is the speed control board.
__________________
  #3 (permalink)
Old 04-18-2009, 05:19 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
It sounds like at least two of the 3 phase drive transistors blew out on the motor drive board. If so, before replacing the board, I would verify your spin bearings are not going bad. You can sometimes tell by spinning the basket and see if the bearings seem rough. If you replace the motor drive board , you can monitor the motor drive board input current with an amprobe, current over 3 amps is considerd excessive.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
whirlpool washer won't spin manually or spin boniam Washer Repair 15 06-29-2008 07:19 AM
