Discuss
Maytag top loading washer
 in
Washer Repair
I changed out the water inlet valve for a new one, thinking the problem was a sticking cold water valve,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag top loading washer
  #1 (permalink)
Old 09-18-2011, 12:55 PM
Junior Member
WATTSAIA is on a distinguished road
Default Maytag top loading washer
Model Number: LAT9606AAE   Brand: Maytag   Age: 5 - 10 years
I changed out the water inlet valve for a new one, thinking the problem was a sticking cold water valve, with no change in symptom . Same problem , no cold water. I switched the connections on the valves to see if it was a fault or wire break...Same problem, only hot water.
I was thinking it is a worn out water temperature switch in the control console.?
I checked all the connections for corrosion, etc., they look good.
Anybody have any suggestions whether I am on the right track.
Don
Ads By Google
Related Models
Maytag LAT9606AAE Washer - Top Loading
Maytag LAT9606AAM Washer - Top Loading
Maytag LAT9606ABE Washer - Top Loading
Maytag LAT9606ABM Washer - Top Loading
International LAT9606AGE Washer - Top Loading
International LAT9606BGE Washer - Top Loading
International LAT9606GGE Washer - Top Loading
Maytag LAT9614AAE Washer - Top Loading
Maytag LAT9614AAL Washer - Top Loading
Maytag LAT9614AAM Washer - Top Loading
Maytag LAT9615AAE Washer - Top Loading
Maytag LAT9615AAM Washer - Top Loading
Maytag LAT9616AAE Washer - Top Loading
Maytag LAT9616AAM Washer - Top Loading
Maytag LAT9634AAE Washer - Top Loading
Maytag LAT9634AAL Washer - Top Loading
Maytag LAT9634AAM Washer - Top Loading
Maytag LAT9634ABE Washer - Top Loading
Maytag LAT9635AAE Washer - Top Loading
Maytag LAT9635AAM Washer - Top Loading
Maytag LAT9700AAG Washer - Top Loading
Maytag LAT9700AAL Washer - Top Loading
Maytag LAT9700AAW Washer - Top Loading
Maytag LAT9700AAX Washer - Top Loading
Maytag LAT9700ABL Washer - Top Loading
Maytag LAT9700ABW Washer - Top Loading
Maytag LAT9700DAG Washer - Top Loading
Maytag LAT9700DAL Washer - Top Loading
Maytag LAT9700DAW Washer - Top Loading
Maytag LAT9704AAE Washer - Top Loading
Maytag LAT9704AAL Washer - Top Loading
Maytag LAT9704AAM Washer - Top Loading
Maytag LAT9704ABE Washer - Top Loading
Maytag LAT9704ABL Washer - Top Loading
Maytag LAT9704ABM Washer - Top Loading
International LAT9704AGE Washer - Top Loading
International LAT9704BGE Washer - Top Loading
Maytag LAT9704DAL Washer - Top Loading
Maytag LAT9704DAM Washer - Top Loading
International LAT9704GGE Washer - Top Loading
Maytag LAT9706AAE Washer - Top Loading
Maytag LAT9706AAM Washer - Top Loading
Maytag LAT9706AAQ Washer - Top Loading
Maytag LAT9706ABE Washer - Top Loading
Maytag LAT9714AAE Washer - Top Loading
Maytag LAT9714AAL Washer - Top Loading
Maytag LAT9714AAM Washer - Top Loading
Maytag LAT9734AAE Washer - Top Loading
Maytag LAT9734AAL Washer - Top Loading
Maytag LAT9734AAM Washer - Top Loading
Maytag LAT9734ABE Washer - Top Loading
Maytag LAT9734ABL Washer - Top Loading
Maytag LAT9757AAE Washer - Top Loading
Maytag LAT9757AAM Washer - Top Loading
Maytag LAT9766AAE Washer - Top Loading
Maytag LAT9800AAL Washer - Top Loading
Maytag LAT9800AAW Washer - Top Loading
Maytag LAT9800ABL Washer - Top Loading
Maytag LAT9800ABW Washer - Top Loading
Maytag LAT9800AGL Washer - Top Loading
Maytag LAT9800AGW Washer - Top Loading
Maytag LAT9800AGX Washer - Top Loading
Maytag LAT9804AAE Washer - Top Loading
Maytag LAT9804AAL Washer - Top Loading
Maytag LAT9804AAM Washer - Top Loading
Maytag LAT9804ABE Washer - Top Loading
Maytag LAT9806AAE Washer - Top Loading
Maytag LAT9806AAM Washer - Top Loading
Maytag LAT9806ABE Washer - Top Loading
International LAT9806AGE Washer - Top Loading
International LAT9806AKM Washer - Top Loading
International LAT9806AKQ Washer - Top Loading
International LAT9806BGE Washer - Top Loading
International LAT9806DAM Washer - Top Loading
International LAT9806DAQ Washer - Top Loading
International LAT9806GGE Washer - Top Loading
Maytag LAT9824AAE Washer - Top Loading
Maytag LAT9824AAL Washer - Top Loading
Maytag LAT9824AAM Washer - Top Loading
Maytag LAT9824ABE Washer - Top Loading
Maytag LAT9824ABL Washer - Top Loading
Maytag LAT9824ABM Washer - Top Loading
International LAT9824AGE Washer - Top Loading
International LAT9824AKM Washer - Top Loading
International LAT9824BGE Washer - Top Loading
International LAT9824DAM Washer - Top Loading
International LAT9824GGE Washer - Top Loading
Maytag LAT9900AAL Washer - Top Loading
Maytag LAT9900AAW Washer - Top Loading
Maytag LAT9900ABL Washer - Top Loading
Maytag LAT9900ABW Washer - Top Loading
Maytag LAT9904AAE Washer - Top Loading
Maytag LAT9904AAL Washer - Top Loading
Maytag LAT9904AAM Washer - Top Loading
Maytag LAT9904ABE Washer - Top Loading
Admiral LATA100AAE Washer - Top Loading
Admiral LATA100AAL Washer - Top Loading
Admiral LATA100AAM Washer - Top Loading
Admiral LATA100AAW Washer - Top Loading
Admiral LATA100AGE Washer - Top Loading
Admiral LATA100AJE Washer - Top Loading
Admiral LATA100AKE Washer - Top Loading
Admiral LATA100ARE Washer - Top Loading
Admiral LATA200AAE Washer - Top Loading
Admiral LATA200AAL Washer - Top Loading
Admiral LATA200AAM Washer - Top Loading
Admiral LATA200AAW Washer - Top Loading
Admiral LATA200AGE Washer - Top Loading
Admiral LATA200AJE Washer - Top Loading
Admiral LATA200AJM Washer - Top Loading
Admiral LATA300AAE Washer - Top Loading
Admiral LATA300AAL Washer - Top Loading
Admiral LATA300AAM Washer - Top Loading
Admiral LATA300AAW Washer - Top Loading
Admiral LATA300AGA Washer - Top Loading
Admiral LATA300AGL Washer - Top Loading
Admiral LATA300AGW Washer - Top Loading
Admiral LATA400AAE Washer - Top Loading
Admiral LATA400AAL Washer - Top Loading
Admiral LATA400AAM Washer - Top Loading
  #2 (permalink)
Old 09-20-2011, 06:39 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Are you sure the cold water is on from the tap. When you switched out the connections on the valve you should have gotten cold water and no hot.
__________________
  #3 (permalink)
Old 09-20-2011, 06:54 PM
Junior Member
Quote:
I unhooked the cold water hose and cold water came out. Could it be the water temperature control switch in the console ? Is there another component that could be causing this behavior? I am ready to try replacing the switch box.
I have also replaced the hoses thinking it could be some sort of blockage.
No dice...
  #4 (permalink)
Old 09-21-2011, 05:23 AM
Senior Expert
APP Volunteer
Default
I am going to say try changing out the temp control switch, but this is still somewhat of a mystery.
__________________
  #5 (permalink)
Old 09-28-2011, 12:17 PM
Junior Member
Default Maytag Toploading washer, the on going adventure
Well, I replaced the water temperature switches in the console, no dice still no cold water. Sofar I have replaced the hoses to the inlet valve, and the inlet valve. I am out of ideas. I have the sneaky suspician I am slowly building a new washing machine. Does anyone have any idea of what the problem is?
I am a stubborn Scotsman who does know when to quit....
  #6 (permalink)
Old 09-28-2011, 12:22 PM
Junior Member
Default Maytag toploading problem
I am a stubborn Scotsman who doesn't know when to quit.
  #7 (permalink)
Old 09-29-2011, 02:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
May be time to recap what you have done and diagnose that.
I do not think the control switch is the problem.
Diagnosis:
You have hot water so you know the hot valve gets power.
When you switched the lines to the valve. Hot power is now on the cold valve and cold power is on the hot valve.
You get hot water so you know that the cold power is OK.
Conclusion:
Power is OK to both the hot and cold valves.
Conclusion: You have cold water.
Did the water come out at the same rate as the hot water?
Does the house plumbing have a burst hose protection system? These can do all sorts of not so wonderful things.
Swap the hoses at the valve. Run a cold only cycle if it fills with hot water then you know that there is a problem either with the cold hose or the house water supply.
If it does not fill then I would say that you received a defective inlet valve.
The odds of getting a defective valve with exactly the same symptoms as the one you replaced are slim but not impossible.
I hope the above makes sense.
sidfink43 If you see this and since you are the washing machine guru, does it make sense?
__________________
  #8 (permalink)
Old 09-29-2011, 06:24 AM
Senior Expert
APP Volunteer
Default
Denman
I agree with everything you say. The individual did say that he has cold water from the hose, which leads to your conclusion that the replacement valve assembly was also defective, which is just highly unusual.
If he was getting hot water after switching the connectors then he is getting power to both the hot and cold water solenoids and if he is getting hot and cold water from the hoses the valve assembly has to be the problem.
The only other explanation is that when the valve assembly was replaced he accidentally put the old one back in. Don't laugh, can't tell you how many times I have done that.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis top loading washer doesn't spin out water ramchaza Washer Repair 2 03-22-2010 09:47 AM
Maytag Top Loading Washer - purchased 1997 Atlas1 Washer Repair 1 02-01-2010 11:34 AM
Maytag top loading washer tub leaking Rod Gray Washer Repair 2 01-29-2010 03:28 AM
Maytag Top Loading Washer Lisa1966 Washer Repair 1 12-21-2009 12:24 PM
Maytag Top Loading Washer dpalatka Washer Repair 8 03-18-2008 03:28 AM
