Discuss
Broken Maytag A510 Real tough to spin
 in
Washer Repair
I have a broken Maytag A510 washer. I would like to keep this good old washer going but I need
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Broken Maytag A510 Real tough to spin
  #1 (permalink)
Old 09-18-2011, 11:59 AM
Junior Member
chevy63127 is on a distinguished road
Default Broken Maytag A510 Real tough to spin
Model Number: a510   Brand: Maytag   Age: More than 10 years
I have a broken Maytag A510 washer. I would like to keep this good old washer going but I need some help.
the main drive belt is slipping while washing. I can turn the drum but it's real tight, in both directions. It will free up and spin easily but then tighten up again. The agitator turns with the drum as well in both directions, but not freely on its own.
I'm thinking I have a trans problem or a jambed up agitator. There are no bolts under the cup/lint screen on the agitator so I'm unsure how to remove it to check.
Also if it's the trans, are they repairable? I'm not going to fix it if I need to replace the trans, but would consider fixing the internals of the trans if it's a cheaper part.
thanks
Edit. I put new belts on it last year because it smoked the drive belt. Probably the same problem.
And I just put new glides and springs on the motor mount plate.
Ads By Google
Related Models
Maytag A510 WASHER-TOP LOADING
Maytag A510S WASHER-TOP LOADING
Maytag A511 WASHER-TOP LOADING
Maytag A511S WASHER-TOP LOADING
Maytag A512 WASHER-TOP LOADING
Maytag A512S WASHER-TOP LOADING
Jenn-Air A516 MISC / ACCESSORY
Jenn-Air A518S MISC / ACCESSORY
Jenn-Air A519 MISC / ACCESSORY
Jenn-Air A519W MISC / ACCESSORY
Jenn-Air A521B MISC / ACCESSORY
Jenn-Air A521W MISC / ACCESSORY
Jenn-Air A526 MISC / ACCESSORY
Jenn-Air A526W MISC / ACCESSORY
Jenn-Air A527B MISC / ACCESSORY
Jenn-Air A530 MISC / ACCESSORY
Jenn-Air A530W MISC / ACCESSORY
Admiral A54F-5TKXW-R WALLOVEN- S/C GAS
Admiral A54F-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FK-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FN-5TKVW-R WALLOVEN- S/C GAS
Admiral A54FN-5TKVWM-R WALLOVEN- S/C MWAVE GAS
Admiral A5651XRS RANGE- D/I CONT CLEAN ELE
Admiral A5892XRS RANGE- S/C D/I ELE
Admiral A5898VRV RANGE- S/C D/I ELE
Admiral A5898XRB RANGE- S/C D/I ELE
Admiral A59-5EXW-R WALLOVEN- S/C ELE
Maytag A590 WASHER-TOP LOADING
Maytag A5910 WASHER-TOP LOADING
Admiral A59E-5EXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59FN-5TVW-R WALLOVEN- S/C ELE
Admiral A59FN-5TVWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59G-5TXW-R RANGE- F/S STD ELE
Admiral A59GN-5TVW-R RANGE- F/S STD ELE
Frigidaire A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag A606 WASHER-TOP LOADING
Maytag A606S WASHER-TOP LOADING
Maytag A608 WASHER-TOP LOADING
Maytag A608S WASHER-TOP LOADING
Maytag A610 WASHER-TOP LOADING
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
Admiral A8241RS SURFACE UNIT- GAS
Admiral A8241RT-L SURFACE UNIT- GAS
Admiral A8241RV SURFACE UNIT- GAS
Admiral A8241RW SURFACE UNIT- GAS
Admiral A8241RW-L SURFACE UNIT- GAS
Admiral A8261RB SURFACE UNIT- GAS
Admiral A8261RV SURFACE UNIT- GAS
Admiral A82LK-3K-R SURFACE UNIT- GAS
Admiral A82LN-3K-R SURFACE UNIT- GAS
Admiral A82LW-2K-R SURFACE UNIT- GAS
Admiral A8321PA SURFACE UNIT- GAS
Admiral A8321PS SURFACE UNIT- GAS
Admiral A8321PW SURFACE UNIT- GAS
Admiral A8321TA-L SURFACE UNIT- GAS
Admiral A8321TW-L SURFACE UNIT- GAS
Maytag A8340 WASHER-TOP LOADING
  #2 (permalink)
Old 09-20-2011, 06:26 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It does sound like the transmission, which is not a repairable item and is replaced as a unit.
I know you want to keep this unit, but I strongly suggest using the money you would put into a new transmission to put into a new machine.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Real Time Help With Maytag Atlantis lute Washer Repair 1 07-25-2011 07:05 PM
Micro tough place for a screw? garypriceomaha Microwave Repair 0 06-07-2011 03:44 PM
No lights on tough pad captainbarb Washer Repair 2 02-03-2009 05:08 PM
tough pad problem Larry Phillips Oven Repair (including Ranges and Cooktops) 3 10-22-2008 12:49 PM
