Discuss
roper washer question
 in
Washer Repair
Please take a few seconds and answer if you can! I think the problem is the lid switch because it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » roper washer question
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-02-2007, 07:00 AM
whitehanes34 whitehanes34 is offline
Junior Member
whitehanes34 is on a distinguished road
Smile roper washer question
Model Number: ras6233.kq2   Brand: Roper   Age: 1 - 5 years
I think the problem is the lid switch because it previously would run with lid open, then would not run with lid down, now is working fine again.
I have ordered and received a new lid switch but not put it on yet.
My question: Simply, how do i get to the switch?
I asked this a week or so ago, 20 people read it, and noone bothered to take a second and answer. I just want to know the way the top of the machine lifts up. Please help!
thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2007, 07:19 AM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Look at the rear of the control panel on the ends and find the screws that hold the panel to the washer top. Back out the screws until you can slide the panel forward about and inch and flip it over toward the back of the unit. Under the panel, remove the plug to the lid switch and release the gold colored brackets on each end. This will allow the top of the unit to tip forward off the frame (pay attention to how it came off). After you change the switch, make sure you get the top back on just as you took it off. There are tabs on the frame in the rear that must fit into the slots of the washer housing. Reinstall the brackets (if they don't go on easily, the cabinet isn't on correctly) and the lid switch connector, then reinstall the control panel. Hope this helps.
TechnicianBrian
  #3 (permalink)
Old 12-02-2007, 12:03 PM
Junior Member
Default roper lid question
yes it greatly helps, brian, and i thank you.
i can tear anything down and put it back together but rather know exactly which way to go first.
thanks again
allen
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Vacuum Question/Help??? truszip General Talk 3 02-20-2008 06:17 PM
Roper Washer Noise/Alarm during wash cycle neworleans70 Washer Repair 2 11-25-2007 07:14 AM
ignitor question Rod Weeks Oven Repair (including Ranges and Cooktops) 0 11-15-2007 06:14 PM
Roper washer will not spin rodtamara Washer Repair 0 11-12-2007 03:35 PM
Question for dryer repair svaughan Dryer Repair 1 09-19-2007 07:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
