| » maytag neptune washer bleach dispenser |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Brand: Maytag Age: 1 - 5 years
I have had this washer for about 3 1/2 years, no problems till now.
When I start the wash cycle water fills the bleach dispenser also. Everything else seems to work fine wash, rinse, spin. I can't use the bleach because of this. |
In order to give the most accurate advise I need the complete model number of the washer.
__________________
Professional appliance repair services in Orange County, California. |
Most likely the problem is a shorted bleach solenoid on the dispenser water valve (#14 on the control panel & top break down diagram) or a shorted control board (#17 on the control panel & top break down diagram).
You can find more specific instructions in the service manual. - The part number for the dispenser water valve AP3464761 - The part number for the main control board AP3449382 - Here are the break down diagrams for the Maytag Neptune washer Model MAH6500AWW Gene.
__________________
I'm having the same problem, but my Maytag Neptune model number is MAH3000AWW. The parts diagram doesn't seem to show a solenoid for this model. Which part is the most likely culprit and which components must be removed in order to access it? Any suggestions would be greatly appreciated.
jjrapp,
Most likely the problem is a bad wax motor in the dispenser. This part does not come separate and you have to replace the whole dispenser assembly. - The part number for the dispenser assembly is AP252043 Here are the break down diagrams for the Maytag Neptune washer Model MAH3000AWW Gene.
__________________
Thanks for the quick reply. Now I can't figure out how to access the dispenser assembly. The top cover seems to be held down by the top cover spacers and the corner braces. Perhaps I have to remove the door and the shroud brackets first? Or is there a quick release for the top cover?
__________________
We're glad you were able to fix it.
__________________
| Display Modes | |
| Bleach dispenser not working | ZinToledo | Washer Repair | 7 | 12-02-2007 01:47 PM |
| Maytag Neptune Washer overfilling | badace | Washer Repair | 0 | 12-01-2007 10:08 PM |
| Maytag Neptune Washer model # mah5500bww | Scotty | Washer Repair | 1 | 10-22-2007 04:29 PM |
| Maytag Neptune Clothes washer | AnnieB | Washer Repair | 1 | 09-19-2007 04:03 AM |
| Maytag Neptune Washer | utep42 | Washer Repair | 1 | 08-31-2007 03:59 PM |
