Discuss
Will not drain, not clogged
 in
Washer Repair
The machine will fill, aggitate but it won't drain. Don't know if it will spin because it has to drain
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Will not drain, not clogged
  #1 (permalink)
Old 12-02-2007, 12:17 AM
Junior Member
Jimmy is on a distinguished road
Default Will not drain, not clogged
Model Number: 10092284100   Brand: Kenmore   Age: More than 10 years
The machine will fill, aggitate but it won't drain. Don't know if it will spin because it has to drain first. I pulled the pump off and it is not clogged, and seems to be ok. Also when you advance the timer drain you dont hear anything like a pump trying to start.
Ads By Google
Related Models
Amana 100A-20 Room Air Conditioner
Amana 100A-2M Room Air Conditioner
Amana 100A-2N Room Air Conditioner
Amana 100A-30 Room Air Conditioner
Amana 100A-30H Room Air Conditioner
Amana 100A-356 Room Air Conditioner
Amana 100A-3A Room Air Conditioner
Amana 100A-3HN Room Air Conditioner
Amana 100A-3M Room Air Conditioner
Amana 100A-3N Room Air Conditioner
Amana 100A-3P Room Air Conditioner
Amana 100A-3PH Room Air Conditioner
Amana 100A-3R Room Air Conditioner
Amana 100A-3RH Room Air Conditioner
Amana 100A-556 Room Air Conditioner
Amana 100A-8R Room Air Conditioner
Amana 100B-3A Room Air Conditioner
Amana 100C-20
Amana 100C-20H
Amana 100C-2N Room Air Conditioner
Amana 100C-2N1 Room Air Conditioner
Amana 100C-2P Room Air Conditioner
Amana 100C-2PH Room Air Conditioner
Amana 100C-2R Room Air Conditioner
Amana 100C-2RH Room Air Conditioner
Amana 100C-2RHL Room Air Conditioner
Amana 100C-2RL Room Air Conditioner
Amana 100C-30
Amana 100C-30H
Amana 100C-3N Room Air Conditioner
Amana 100C-3N1 Room Air Conditioner
Amana 100C-3P Room Air Conditioner
Amana 100C-3PH Room Air Conditioner
Amana 100C-3R Room Air Conditioner
Amana 100C-3RH Room Air Conditioner
Amana 100C-3RHL Room Air Conditioner
Amana 100C-3RL Room Air Conditioner
Amana 100C-8P Room Air Conditioner
Amana 100C-8R Room Air Conditioner
Amana 100C-8RH Room Air Conditioner
Amana 100C-8RHL Room Air Conditioner
Amana 100C-8RL Room Air Conditioner
Amana 100D-2HM
Amana 100D-2M
Amana 100D-2MA
Amana 100D-2MB
Amana 100D-356 Room Air Conditioner
Amana 100D-3M
Amana 100D-556 Room Air Conditioner
Amana 100LA-20 Room Air Conditioner
Amana 100LA-2N Room Air Conditioner
Amana 100LC-20
Amana 100LC-2N Room Air Conditioner
Amana 100LC-2P Room Air Conditioner
Amana 100LC-2R Room Air Conditioner
Amana 100LC-2RH Room Air Conditioner
Amana 100LCS-20
Amana 100LCS-2N Room Air Conditioner
Amana 100LCS-2P Room Air Conditioner
Hoover 1010
Amana 1010.000 Mwave - Family Size (60 Hz)
Amana 1011.000 Mwave - Family Size (60 Hz)
Amana 1015.000 Mwave - Family Size (60 Hz)
Amana 1018.000 Mwave - Family Size (60 Hz)
Amana 102.000 Mwave - Family Size (60 Hz)
Amana 102.001 Mwave - Family Size (60 Hz)
Amana 102.002 Mwave - Family Size (60 Hz)
Hoover 1020
Amana 1020.0 Mwave - Family Size (60 Hz)
Amana 1020.000 Mwave - Family Size (60 Hz)
Amana 1021.000 Mwave - Family Size (60 Hz)
Whirlpool 1021B16
Whirlpool 1021B26
Whirlpool 1021B36
Whirlpool 1021B46
Hoover 1022 Frigidaire/electric Range
Amana 1022.000 Mwave - Family Size (60 Hz)
Kenmore 103.103970  L.P. CONVERSION KIT
Kenmore 103.103972  L.P. CONVERSION KIT
Kenmore 103.103973  MFG. CONVERSION KIT
Kenmore 103.105441  L.P. CONVERSION KIT
Kenmore 103.107885  MFG CONVERSION KIT
Kenmore 103.108077  L.P. CONVERSION KIT
Kenmore 103.108078  MFG. CONVERSION KIT
Kenmore 103.110997  MFG. CONVERSION KIT
Kenmore 103.110999  L.P. CONVERSION KIT
Kenmore 103.112907  L.P. CONVERSION KIT
Kenmore 103.3017000  LINER KIT
Kenmore 103.30181  KENMORE GAS OVEN
Kenmore 103.3023200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3023210  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3025200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3026520  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3026521  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3033400  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3033410  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035000  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035400  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035500  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035600  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035800  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3035900  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036500  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036501  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036540  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036541  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036550  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036551  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036560  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036561  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036580  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036581  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036590  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3036591  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.30381  KENMORE GAS OVEN
Kenmore 103.3043200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3043210  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3045200  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3046520  KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 103.3046521  KENMORE GAS BUILT-IN OVEN UNIT
  #2 (permalink)
Old 12-02-2007, 10:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem with your washer is a bad lid switch (#11 on the break down diagram).
- The part number for the lid switch AP3094500
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drain Line clogged JLMoon Refrigerator & Freezer Repair 3 04-13-2013 08:39 AM
Defrost drain clogged billkenny Refrigerator & Freezer Repair 10 05-29-2010 10:47 AM
Clogged drain hose maroon3 Washer Repair 0 04-04-2009 12:29 PM
Clogged defrost drain w491cz Refrigerator & Freezer Repair 1 06-10-2008 11:09 PM
Defrost drain clogged billkenny Refrigerator & Freezer Repair 1 06-05-2008 12:52 PM
