Discuss
Kenmore 70 series won't spin
 in
Washer Repair
Hi I'll try to keep this brief. After the spin cycle, clothes were pretty wet and had to be spun
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 70 series won't spin
  #1 (permalink)
Old 09-17-2011, 10:29 AM
Junior Member
kieranlocko is on a distinguished road
Default Kenmore 70 series won't spin
Brand: Kenmore   Age: 5 - 10 years
Hi
I'll try to keep this brief. After the spin cycle, clothes were pretty wet and had to be spun 2 or 3 times. I am a complete novice, but handy, so opened up the machine to look for anything blatantly obvious. Saw nothing, put it back together, but now on spin it chugged and tub looked like it was catching. Opened it up again and replaced the motor coupler (which did look kind of worn). Put it back together again but still makes a noise like it's catching, and doesn't spin. Next removed the agitator, and took the entire motor and clutch/ shaft assembly out. These parts seem to turn freely (although the clutch turns only in a clockwise direction, counter clockwise it stops after about a full turn). Tried holding the brake cam and turning the drive tube; it moves very easily in a counter clockwise direction but appears to be catching in a clockwise direction, and I hear a click as I turn it.
Any ideas? Have I completely screwed it up. I hope to be able to repair it myself....
thanks in anticipation .
Ads By Google
  #2 (permalink)
Old 09-18-2011, 06:04 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I am not sure what you mean when you say the clutch will not turn in both directions. If the transmission will not turn in one direction that it is probably the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 series will not spin mkeaton Washer Repair 1 09-02-2011 04:58 PM
Kenmore 90 series won't spin on its own andyloeb Washer Repair 1 10-30-2010 05:46 PM
Kenmore 80 Series won't spin Kristine Washer Repair 6 08-01-2010 11:21 PM
Kenmore 90 Series no spin mfalkevitz Washer Repair 1 10-02-2009 03:35 AM
kenmore series 80 will not spin tlgeirna Washer Repair 1 06-04-2008 02:51 AM
