Paulleekelley
#1 Posted : Wednesday, April 15, 2009 9:51:54 AM(UTC)
Paulleekelley
Model AAV-1 / Part #35-6940
My wash machine has begun making a loud rattling/clicking noise when the machine goes onto rinse and spinning cycle and yesterday it stopped during the rinse cycle. There was a slight burning smell??? The water was still in the machine so I reset it and it did nothing.
I waited a few hours and plugged the machine back in and set it on the spin cycle to get the water out the machine. It worked but was still making this rattling/clanking/clicking noise.
What do I need to repair it, or has it run it's course???
Many Thanks,
Paul.
#2 Posted : Wednesday, April 15, 2009 11:31:40 AM(UTC)
Paul,
Sounds like the problem is a bad pump. The model number you posted is incomplete or incorrect. You should look for it on the washer (most likely under the lid) and not in the manual.
Paulleekelley
#3 Posted : Wednesday, April 15, 2009 11:34:24 AM(UTC)
Paulleekelley
How do I confirm that this is the problem before I purchase a new pump???
#4 Posted : Wednesday, April 15, 2009 6:08:09 PM(UTC)
How can I help you better without the correct model number?
Paulleekelley
#5 Posted : Thursday, April 16, 2009 5:09:03 AM(UTC)
Paulleekelley
Model number is AAV7000aww
#6 Posted : Thursday, April 16, 2009 6:26:35 PM(UTC)
Lift the washer up from the front. Remove the belt and manually check how the pump pulley rotates in both directions.
- The part number for the pump is AP4373022
Here are the breakdown diagrams and Replacement parts for ADMIRAL AAV7000AWW | AppliancePartsPros.com
Paulleekelley
#7 Posted : Sunday, April 19, 2009 10:12:14 AM(UTC)
Paulleekelley
It rotates free one way(clockwise) and uneasy the other way,(anti clockwise) it has resist and springs back???? Do I need a new pump?
#8 Posted : Monday, April 20, 2009 2:17:10 PM(UTC)
Yes, the pump is bad. No doubt about it.
mephipps1
#9 Posted : Tuesday, February 28, 2012 7:27:52 PM(UTC)
mephipps1
is it good to replace the belt when replacing the water pump?
#10 Posted : Wednesday, February 29, 2012 1:43:07 PM(UTC)
Yes, it is a good idea.
