I had a water leak around the stem seal and replaced the stem seal and outer hub seal. All went fine except adjusting inner tub not to hit outer tub during spin cycle. I've gotten it almost free from hitting but it still touches it slighty. My questions is, is there an easy way to adjust the inner tub to spin freely? Thanks,
Remove the top of the tub and check for a wobling spin basket, if wobling, you will need to loosten the tub nut and reposition the basket.
There is no trick on centering it? It's just trial and error?
