Discuss
LG front load IE error - drain pump stuck on
 in
Washer Repair
My front load LG washer has been working great since I bought it new 2 years ago (just now beyond
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG front load IE error - drain pump stuck on
  #1 (permalink)
Old 09-15-2011, 01:53 PM
Junior Member
bcmike is on a distinguished road
Default LG front load IE error - drain pump stuck on
Model Number: wm2010cw   Brand: -other-   Age: 1 - 5 years
My front load LG washer has been working great since I bought it new 2 years ago (just now beyond the extended warranty). Last week a heavy bath mat caused an unbalanced load and the washer shook quite violently when it was spinning before I shut it off. Ever since, the washer displays an ie error after trying to fill for 10 minutes or so.
I've followed the recommended steps to fix the IE error, checked the inlet hoses, cleaned the inlet filters (weren't very dirty), and even tested the fill level switch and hose inside the machine. all checked out fine.
I believe the problem has to do with the drain pump being stuck on during the fill cycle. As the washer is filling with water, it is constantly being drained so it never fills up. As a test, I deliberately clogged the drain trap with a rolled up sock and the washer filled up in a couple of minutes then the cycle continued without any error, although I stopped it since it obviously took forever to drain. It is not a drain siphoning problem - the drain is fed into a standpipe above the top of the washer and it has plenty of room to breathe. I also ran through the diagnostic test in the LG service manual and during the test it sounds like the drain pump is running the entire time.
Could it be a wire was disconnected somewhere while it was shaking? I've got the top and back panels off the machine now but I'm not sure where else I should look for the problem? I assume I need to take the front panel off if I need to access the drain pump?
Ads By Google
Related Models
Jenn-Air WM227B Walloven - S/c Mwave Ele
Jenn-Air WM227W Walloven - S/c Mwave Ele
Jenn-Air WM236B Walloven - S/c Mwave Ele
Jenn-Air WM236W Walloven - S/c Mwave Ele
Jenn-Air WM27160B Walloven - S/c Mwave Ele
Jenn-Air WM27160W Walloven - S/c Mwave Ele
Jenn-Air WM2720B Walloven - S/c Mwave Ele
Jenn-Air WM2720W Walloven - S/c Mwave Ele
Jenn-Air WM27260B Walloven - S/c Mwave Ele
Jenn-Air WM27260W Walloven - S/c Mwave Ele
Jenn-Air WM27460B Walloven - S/c Mwave Ele
Jenn-Air WM27460W Walloven - S/c Mwave Ele
Jenn-Air WM2750B Walloven - S/c Mwave Ele
Jenn-Air WM2750W Walloven - S/c Mwave Ele
Jenn-Air WM277B Walloven - S/c Mwave Ele
Jenn-Air WM277W Walloven - S/c Mwave Ele
Jenn-Air WM2780 Walloven - S/c Mwave Ele
Jenn-Air WM2780B Walloven - S/c Mwave Ele
Jenn-Air WM2780W Walloven - S/c Mwave Ele
Jenn-Air WM30460B Walloven - S/c Mwave Ele
Jenn-Air WM30460W Walloven - S/c Mwave Ele
Amana WM612 Mwave - Cntrtp / Stand Alone
Amana WM614 Mwave - Cntrtp / Stand Alone
Amana WM615 Mwave - Cntrtp / Stand Alone
Amana WM712 Mwave - Cntrtp / Stand Alone
Amana WM714 Mwave - Cntrtp / Stand Alone
Amana WM715 Mwave - Cntrtp / Stand Alone
General Electric WMCD2050G0WC Washer
Jenn-Air WME3020B Walloven - S/c Mwave Ele
Jenn-Air WME3020W Walloven - S/c Mwave Ele
Jenn-Air WMG3020B Walloven - S/c Mwave Gas
Jenn-Air WMG3020W Walloven - S/c Mwave Gas
General Electric WMR04BANABB Refrigerator
General Electric WMR04BANBBB Refrigerator
General Electric WMR04BANCBB Refrigerator
General Electric WMR04BANDBB Refrigerator
General Electric WMR04BAPABB Refrigerator
General Electric WMR04DATABB Refrigerator
General Electric WMSE3140A0AA Washer
General Electric WMSE3140A0WW Washer
General Electric WMSE3140A2WW Washer
General Electric WMSE3140A3WW Washer
General Electric WMSE4190A0AA Washer
General Electric WMSE4190A0WW Washer
General Electric WMSE4230A0WW Washer
General Electric WMSR2090T2AA Washer
General Electric WMSR2090T2WW Washer
General Electric WMSR2090T3AA Washer
General Electric WMSR2090T3WW Washer
General Electric WMSR2090T5AA Washer
General Electric WMSR2090T5WW Washer
General Electric WMSR2100T6AA Washer
General Electric WMSR2100T6WW Washer
General Electric WMSR2100T8AA Washer
General Electric WMSR2100T8WW Washer
General Electric WMSR2100TAAA Washer
General Electric WMSR2100TAWW Washer
General Electric WMSR2100TBAA Washer
General Electric WMSR2100TBWW Washer
General Electric WMSR3110W1WW Washer
General Electric WMSR3110W2WW Washer
General Electric WMXR3080T2AA Washer
General Electric WMXR3080T2WW Washer
General Electric WMXR3080T3AA Washer
General Electric WMXR3080T3WW Washer
General Electric WMXR3080T5AA Washer
General Electric WMXR3080T5WW Washer
General Electric WMXR3080T6AA Washer
General Electric WMXR3080T6WW Washer
General Electric WMXR3080T8AA Washer
General Electric WMXR3080T8WW Washer
General Electric WMXR3080TAAA Washer
General Electric WMXR3080TAWW Washer
Bosch WMZ2200
General Electric WNCD2050A0WC Washer
General Electric WNCD2050A1WC Washer
General Electric WNCD2050A2WC Washer
General Electric WNCD2050A9WC Washer
General Electric WNCD2050B9WC Washer
General Electric WNCJ2050A0WC Washer
General Electric WNCJ2050A1WC Washer
General Electric WNCJ2050D0WC Washer
General Electric WNCK2050A0WC Washer
General Electric WNCK2050A1WC Washer
General Electric WNCK2050D0WC Washer
General Electric WNCK2050D1WC Washer
General Electric WNCK2050D1WW Washer
General Electric WNRD2050D0WC Washer
General Electric WNRD2050D1WW Washer
General Electric WNRD2050DCWC Washer
General Electric WNRE6280D0WW Washer
General Electric WNSB8060B0CC Washer
General Electric WNSB8060B0WW Washer
General Electric WNSB8060B1CC Washer
General Electric WNSB8060B1WW Washer
General Electric WNSB8060B9CC Washer
General Electric WNSB8060B9WW Washer
General Electric WNSB9080B0CC Washer
General Electric WNSB9080B0WW Washer
General Electric WNSB9100B0CC Washer
General Electric WNSB9100B0WW Washer
General Electric WNSE4200A0AA Washer
General Electric WNSE4200A0WW Washer
General Electric WNSE5260D0WW Washer
General Electric WNSE5260D1WW Washer
General Electric WNSE5699A0AA Washer
General Electric WNSE5699A0WW Washer
General Electric WNSE6280B0WW Washer
General Electric WNSE6280B1WW Washer
General Electric WNSE6280B2WW Washer
General Electric WNSE6280B3WW Washer
General Electric WNSR2100T2AA Washer
General Electric WNSR2100T2WW Washer
  #2 (permalink)
Old 09-16-2011, 07:02 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Ok, it sounds like your pump is staying on, which can either be problem with the control unit or the pump itself. I vote for the pump since it works when you make it fill.
I don't work on many of these and do not have one in front of me but I think you do access the pump by taking off the front.
__________________
  #3 (permalink)
Old 09-17-2011, 08:49 AM
Junior Member
Default
Today I disconnected the ground wire from the pump and ran another cycle. (I was able to access the pump from the access hole in the bottom of the machine without taking the front panel off.
The water filled to the proper level in just a minute or two and started washing with no IE error. At the same time, I hooked up my multimeter to the (brown) drain pump wire at the back of the main board and it read 119V throughout the entire cycle, verifying that was getting constant power from the control board. Eventually, as expedted it gave me an 'OE error' after the first wash cycle finished and the water level didn't go down after a few minutes.
I guess that means the main board will have to be replaced?
  #4 (permalink)
Old 09-17-2011, 09:51 AM
Senior Expert
APP Volunteer
Default
yep, sounds like the control unit is sending power to the pump all the time.
__________________
  #5 (permalink)
Old 09-17-2011, 10:26 AM
Junior Member
Default
Well I just called LG Canada and explained my problem. I was happy to see that LG Canada has a 3 year warranty on the controller (as opposed to 2 years in the US). Unfortunately I still have to pay $100 for a service call so they can confirm the problem. I am still wondering if the problem may be something other than the control board? Is there any other component that would trigger the controller to keep the drain pump running?
  #6 (permalink)
Old 09-17-2011, 01:46 PM
Senior Expert
APP Volunteer
Default
I don't have a wiring diagram for that model, but if you have access to it check and see if there is relay. I don't think there is, but if so the relay might be stuck. Otherwise the wiring diagram should show current coming directly out of the board.
__________________
  #7 (permalink)
Old 09-20-2011, 06:55 AM
Junior Member
Default
Turns out it probably was a stuck relay. The LG technician just left. He replaced the control board with a new one and it's working great again. He thinks the drain pump relay somehow got jammed closed in the old control board, which he let me keep.
I discovered from another source that there is actually a service bulletin for this machine:
Service Bulletin no. : WW/M20100276
Date Issued: June 10, 2010
If the software version is: "IU:00"
You'll need a new MAIN BOARD (EBR43249701) and three new STRUTS (383EER3001F)
This only applies to the WM2010CW washer with SERIAL NUMBERS *up to* 906KWxxxxxx
A flaw in the ***software*** caused excessive spin-vibration----which also usually damaged the STRUTS.
NOTE: The new MAIN BOARD will have a ***software version*** of: IU:03
Interestingly both LG Canada and the technician couldn't find any record of this service bulletin, but it sounds like it is exactly what caused my machine to break down. Anyway, the control board was replaced under warranty and I confirmed that it has the newer IU:03 software, so I am happy. Thanks for all the helpful suggestions.
  #8 (permalink)
Old 09-20-2011, 08:00 AM
Senior Expert
APP Volunteer
Default
Well great, glad you got it fixed and that they were able to come through for you.
Good luck with your washer going forward, thanks for updating us also.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
General Electric Front load washer stuck in drain cycle Jasonkmol Washer Repair 5 05-07-2012 09:53 AM
GE Front Load Washer Gets Stuck in Cycle - Error Code E22 loganer Washer Repair 0 08-14-2011 05:44 PM
GE front load pump cbilld Washer Repair 1 04-22-2011 12:00 PM
control panel stuck on neptune front load kdongs Washer Repair 0 09-12-2010 09:39 AM
Front Load Washer Door Stuck GlennaA Washer Repair 1 07-11-2008 06:52 PM
