| » Spins only low RPM |
Model Number: MAH8700AWW Brand: Maytag Age: 5 - 10 years
Original problem...Washer would not spin when load gets to spin cycle. I just purchased and installed a new control board, part# AP4044795 (34001498) from AppliancePartsPro. When I ran the first wash load, the washer stopped and a code 'ND' appeared on the LED screen..(no drain I believe?) Anyhow, I never had an issue before with washer not draining, and you could hear the drain pump running..?? I took the drain pump completely out and inspected the impeller..everything looked clean and there was no foreign objects inside the pump housing... I then restarted the cycle, and it continued on until it got to the rinse/spin cycle... started spinning, but only at a snails pace...stopped at 8 minutes left, then went back to 9 minutes after a couple minutes went by, then continued on to complete the cycle. Only the spin cycle never got any higher than slow speed/rpm. Any help much appreciated!
This is another Maytag disaster as far as engineering and design is concerned.
Here is what they say for no spin Will Not Spin • Check to make sure the door is fully closed. • Check for water left inside the washer. If present, see Will Not Drain. • Perform Board Output Test or Quick Spin Test. (Before test, make sure that the tumbler is empty.) If it doesn’t tumble after the test above, check unbalanced load scenario, Main Control Board, and motor. • Check for loose connections at Machine Control Board, Pressure Switch, Motor, Tach Harness and Motor Control. • Check belt. • Check motor windings resistance. CN9 pins 1 &3 = 11.6ohms ±7%, Pins 1 & 2 = 11.6ohms ±7%, Pins 2 & 3 = 11.6 ohms ±7% This will at least give you a way to test the motor.
__________________
| Display Modes | |
| only spins in reg cyle | sandrad@maine.rr.com | Washer Repair | 1 | 01-17-2011 07:37 AM |
| spins but does not agitate | dmrlearhart | Washer Repair | 0 | 08-21-2010 08:48 AM |
| spins when it wants... | 1000chuck | Washer Repair | 3 | 01-22-2010 07:11 AM |
| Sometimes spins | caymanada | Washer Repair | 5 | 01-11-2010 01:30 AM |
| Spins with a little help | Alphadog | Washer Repair | 1 | 05-23-2009 06:37 PM |
