| » Washer continues to fill up |
Model Number: MAV9750AWW Brand: Maytag Age: 1 - 5 years
I replaced the hoses on the back of the washer it it was leaking in the back. it had also started to continue to fill up even the the waher had started the cycle and now it wont stop filling up at all.. ? water Valve or water sensor ? also it is making a loud noise when it starts to spin... Thank you so much for your time. Renee
If it fills even when washer is off or unplugged, Then the valve needs cleaning or replacing. If it fills during the agitate cycle, but not during drain or spin, then it's probably the water level switch.
Noise during spin is a separate issue, and could have several causes. |
| Display Modes | |
| washer continues to fill when extra rinse buton is depressed | dpinka | Washer Repair | 1 | 01-24-2011 05:14 PM |
| washer continues to fill during spin | burkett-b | Washer Repair | 0 | 07-17-2010 09:01 AM |
| Water Continues To Fill | robinlayton | Washer Repair | 2 | 10-17-2009 01:15 PM |
| wASHER CONTINUES TO FILL THROUGHOUT CYCLE | armyguber | Washer Repair | 1 | 08-06-2009 03:26 PM |
| continues to fill | Vanessa | Washer Repair | 0 | 06-23-2008 02:39 PM |
