Discuss
front loading washer
 in
Washer Repair
I checked out an atf8000fs1 washing machine. At first it coded that the control board thought the door was open.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » front loading washer
  #1 (permalink)
Old 09-13-2011, 03:50 PM
Junior Member
frankh is on a distinguished road
Default front loading washer
Model Number: atf8000sf1   Brand: Frigidaire   Age: 1 - 5 years
I checked out an atf8000fs1 washing machine. At first it coded that the control board thought the door was open. I cleared it, and now it only codes a E5E, which is a communication error. The book says to replace the control board and if that does not work, replace the speed control board. I hate to be a parts swapper and without pinpointing the problem. I ran a spin cycle and the the pump runs for two seconds and shuts off. A minute later it repeats. At the same time the pump comes on, the speed control board is sent 110volts from the control board for the same duration. The motor, however, does not run. I did an ohm test on the motor, which tested good.Which board do you think is bad?
Frank
Ads By Google
Related Models
Frigidaire ATFB6000ES0 Frigidaire/washer
Frigidaire ATFB6000ES1 Frigidaire/washer
Frigidaire ATFB6000FS0 Frigidaire/washer
Frigidaire ATFB7000EG0 Frigidaire/washer
Frigidaire ATFB7000EP0 Frigidaire/washer
Frigidaire ATFB7000ES0 Frigidaire/washer
Frigidaire ATFB7000ES1 Frigidaire/washer
Frigidaire ATG130NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG130NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG130NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG130NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG130NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG130NLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG130NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG130NLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NLW2 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170NCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170NCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170NCW0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG170NCW1 Wwh(v7) / Top Mount Refrigerator
Frigidaire ATG170NCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170NLD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170NLD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG170NLW1 Wwh(v8) / Top Mount Refrigerator
Frigidaire ATG170NLW2 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170VNCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170VNCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170VNCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170VNCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170VNLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170VNLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170VNLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170VNLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG173NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG173NCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG173NCW0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG173NCW1 Wwh(v7) / Top Mount Refrigerator
Frigidaire ATG173NLD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG173NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG173NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG173NLW1 Wwh(v8) / Top Mount Refrigerator
Frigidaire ATG175NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG175NCD1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG175NCW0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG175NCW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG175NLD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG175NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG180VNCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG180VNCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG180VNLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG180VNLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG185NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG185NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG185NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG185NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG185NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG185NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATL/ATN130BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL/ATN130HK1 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL/ATN130WK1 Frg(v3) / Top Mount Refrigerator
General Electric ATL04LAA1 Room air conditioner
General Electric ATL05LAB1 Room air conditioner
Frigidaire ATL130BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL130BK1-23 Tap(v19) / Top Mount Refrigerator
Frigidaire ATL130BKD1 Gib(v13) / Top Mount Refrigerator
Frigidaire ATL130BKL1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL130BL0 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL130HK1 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL130HK1-66 Tap(v21) / Top Mount Refrigerator
Frigidaire ATL130HKH1 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL130HKJ1 Kel(v27) / Top Mount Refrigerator
Frigidaire ATL130HKY1 Gib(v15) / Top Mount Refrigerator
Frigidaire ATL130WK1 Frg(v5) / Top Mount Refrigerator
Frigidaire ATL130WK1-00 Tap(v23) / Top Mount Refrigerator
Frigidaire ATL130WKW1 Wwh(v11) / Top Mount Refrigerator
Frigidaire ATL130WL0 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL150BK2 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL150HK2 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL150WK2 Tap(v7) / Top Mount Refrigerator
Frigidaire ATL150WKD2 Gib(v15) / Top Mount Refrigerator
Frigidaire ATL150WKH2 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL150WKJ2 Kel(v26) / Top Mount Refrigerator
Frigidaire ATL150WKL2 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL150WKW2 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL150WKY2 Gib(v14) / Top Mount Refrigerator
Frigidaire ATL152BK0 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL152BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL152HK0 Frg(v0) / Top Mount Refrigerator
Frigidaire ATL152WK0 Gib(v12) / Top Mount Refrigerator
Frigidaire ATL152WK1 Frg(v2) / Top Mount Refrigerator
General Electric ATM04LAA1 Room air conditioner
General Electric ATM04LAA2 Room air conditioner
General Electric ATM04LBA1 Room air conditioner
General Electric ATM05LAB1 Room air conditioner
General Electric ATM05LAB2 Room air conditioner
General Electric ATM06LAC1 Room air conditioner
General Electric ATM06LAC2 Room air conditioner
General Electric ATM06LBC1 Room air conditioner
Frigidaire ATN130BHKL1 Frg(v2) / Top Mount Refrigerator
Frigidaire ATN130BK1 Frg(v2) / Top Mount Refrigerator
Frigidaire ATN130BK1-23 Tap(v20) / Top Mount Refrigerator
Frigidaire ATN130BK2 Frg(v1) / Top Mount Refrigerator
Frigidaire ATN130BKD1 Gib(v14) / Top Mount Refrigerator
Frigidaire ATN130BL0 Frg(v3) / Top Mount Refrigerator
Frigidaire ATN130HK1 Frg(v4) / Top Mount Refrigerator
Frigidaire ATN130HK1-66 Tap(v22) / Top Mount Refrigerator
  #2 (permalink)
Old 09-14-2011, 06:32 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If the motor control board is getting 110v and the motor does not turn it is likely the motor control board that is the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front loading washer SKIP22 Washer Repair 1 07-24-2011 06:33 PM
GE front loading washer mwsharpe308 Washer Repair 2 06-14-2011 06:44 PM
lg front loading washer tdctim Washer Repair 1 05-20-2011 03:35 PM
front loading washer faithkins Washer Repair 1 08-05-2010 01:32 PM
Front Loading Washer George5 Washer Repair 1 02-27-2008 04:38 PM
