Discuss
Kenmore 80 series will not spin out full load
 in
Washer Repair
The washer will only spin small loads. Every other cycle works. Transmission or clutch? Ads By Google Related Models Kenmore
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 80 series will not spin out full load
  #1 (permalink)
Old 09-12-2011, 04:26 PM
Junior Member
cczhaven is on a distinguished road
Default Kenmore 80 series will not spin out full load
Model Number: 11026882503   Brand: Kenmore   Age: 5 - 10 years
Ads By Google
Related Models
Kenmore 11026892690 TB26-10- WARM RINSE
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
Kenmore 11026902692 AUTOMATIC WASHER
Kenmore 11026904692 AUTOMATIC WASHER
Kenmore 11026912690 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Sears 11027802691 AUTOMATIC WASHER
Sears 11027812690 AUTOMATIC WASHER
Sears 11027812691 AUTOMATIC WASHER
Sears 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Sears 11027824790 AUTOMATIC WASHER
Sears 11027852790 AUTOMATIC WASHER
Sears 11027852791 AUTOMATIC WASHER
Sears 11027862790 AUTOMATIC WASHER
Sears 11027892790 AUTOMATIC WASHER
Sears 11027892791 AUTOMATIC WASHER
Sears 11027894790 AUTOMATIC WASHER
Sears 11027894791 AUTOMATIC WASHER
Sears 11027902790 AUTOMATIC WASHER
Sears 11028299890 AUTOMATIC WASHER
Kenmore 11028802890 AUTOMATIC WASHER
Kenmore 11028803890 AUTOMATIC WASHER
Kenmore 11028812790 AUTOMATIC WASHER
Kenmore 11028822790 AUTOMATIC WASHER
Kenmore 11028822791 AUTOMATIC WASHER
Sears 11028824790 AUTOMATIC WASHER
Kenmore 11028824791 AUTOMATIC WASHER
Kenmore 11028872890 AUTOMATIC WASHER
Kenmore 11028872891 AUTOMATIC WASHER
Kenmore 11028874890 AUTOMATIC WASHER
Kenmore 11028874891 AUTOMATIC WASHER
Kenmore 11028882790 AUTOMATIC WASHER
Kenmore 11028882791 AUTOMATIC WASHER
Sears 11028884790 AUTOMATIC WASHER
Kenmore 11028884791 AUTOMATIC WASHER
Kenmore 11028892790 AUTOMATIC WASHER
Kenmore 11028892791 AUTOMATIC WASHER
Sears 11028894790 AUTOMATIC WASHER
Kenmore 11028894791 AUTOMATIC WASHER
Kenmore 11028902790 AUTOMATIC WASHER
Kenmore 11028902791 AUTOMATIC WASHER
Kenmore 11028912790 AUTOMATIC WASHER
Kenmore 11028912791 AUTOMATIC WASHER
Sears 11028922790 AUTOMATIC WASHER
Kenmore 11028922791 AUTOMATIC WASHER
Sears 11028924790 AUTOMATIC WASHER
Kenmore 11028924791 AUTOMATIC WASHER
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362821 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363076 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364760 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365013 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365196 GEARCASE AND SUPERSTRUCTURE
  #2 (permalink)
Old 09-14-2011, 06:11 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Highly likely the clutch. Click on the Sticky at the top of this page on Direct Drive Brakes by Richappy and you will get info on fixing it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore top load Series 80 won't spin tedmlane Washer Repair 0 09-07-2011 03:26 PM
Maytag Legacy wont spin with a full load kansas Dryer Repair 0 01-20-2010 07:49 AM
dryer will not spin with full load Bottels Dryer Repair 1 08-30-2009 03:42 PM
Kenmore 90 Series won't spin when full kristen_01 Washer Repair 1 07-24-2009 01:00 PM
Roper washer will not spin with a full load DRobison Washer Repair 0 03-13-2009 11:48 AM
