coxcox2u
#1 Posted : Monday, April 13, 2009 3:51:14 AM(UTC)
coxcox2u
Can anyone tell me the probable cause? My washer will not drain after the rinse cycle? It's not the door switch, what else can cause this? It drains after the wash cycle just fine.:confused:
sidfink43
#2 Posted : Tuesday, April 14, 2009 5:32:53 PM(UTC)
sidfink43
Hi
Can you give us some more information.
1. Does the machine go through the spin and drain cycle normally after the wash cycle?
2. Are you saying that it simply stops at the end of the rinse cycle?
3. If you manually move the timer a bit, does it go into spin and drain mode?
4. Why do you not believe it is the lid switch, how have you checked this?
5. After it stops, if you turn the timer around to the end of the wash cycle, does it go into spin and drain?
Hopefully we can give you some suggestions after we get this info.
coxcox2u
#3 Posted : Tuesday, April 14, 2009 5:45:23 PM(UTC)
coxcox2u
THANKS for all the help. It was the Lid Switch! Thanks again, great forum and great people!:D :D :D
