my washer started making a grinding noise on the wash cycle but all other cycle semm to work just fine i do not know what is causing tha noise:eek:
Noises are very difficult diagnose without being there to hear them, but I think your noise is likely coming from the brakes. This repair needs special tools because of the brake spring, which is under 200 lbs of pressure and can be dangerous.
I also found that the tub is about a 1/4" off center is this normal?
Not sure but that doesn't seem like a problem.
