Discuss
Water pulsates during fill.
 in
Washer Repair
I was testing out a used Kenmore washer. I hooked up cold water hoses to both valve inputs (we don't
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water pulsates during fill.
  #1 (permalink)
Old 09-10-2011, 05:00 PM
Junior Member
bsaucer is on a distinguished road
Default Water pulsates during fill.
Brand: Kenmore   Age: 1 - 5 years
I was testing out a used Kenmore washer. I hooked up cold water hoses to both valve inputs (we don't have hot water at the facility). No matter where I set the temperature switch (has built-in ATC), the water pulsates into the tub (about two pulses per second) instead of using a steady stream.
Is this normal? Or would it be the ATC switch or the ATC Sensor in the water valve? I measured the voltages to the valve solenoids, and they both pulsed on and off. The pink wire leading to the ATC switch was on steady.
It wasn't doing this yesterday when it was warm outside (in the 80's), but this morning, it was pulsating badly, but improved over time. The outside temp was in the 60's this morning. I work on the washer outdoors.
Ads By Google
  #2 (permalink)
Old 09-11-2011, 06:15 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Interesting question, have not had that problem. If the valves are pulsating thent he problem could be the control unit or the ATC board.
I cannot think of better advice then to change out parts and see what happens.
If you need more info, please post a model number.
__________________
  #3 (permalink)
Old 09-11-2011, 07:53 PM
Junior Member
Default
I'll get the model number tomorrow. However, the washer has a mechanical timer (no control board), a rotary temp switch with built-in ATC, and a mixing valve having two solenoids and a built-in sensor.
ATC has 6 wires (as per schematic):
pink from pressure switch (empty), timer, and sensor
brown from timer (switch 11)
orange-white from sensor
brown-red to hot valve
yellow-red to cold valve
white from power neutral, also goes to valves.
  #4 (permalink)
Old 09-12-2011, 08:50 AM
Junior Member
Default
Correction: It's a Whirlpool, not Kenmore. Model GST9679PW2.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water dispenser works icemaker will not fill with water rchandle Refrigerator & Freezer Repair 0 05-16-2011 05:36 AM
dryer surges -exhaust air pulsates j-fromm@hotmail.com Dryer Repair 0 04-02-2011 05:02 PM
Water fill is delayed, must wait to have water in rinse cycle sewsmack Washer Repair 0 10-19-2010 02:45 PM
Water dispenser works ice maker will not fill up with water Kim Pratt Refrigerator & Freezer Repair 0 08-29-2010 05:38 PM
Kenmore 60 Series doesn't spin but pulsates netdude75 Washer Repair 1 12-21-2009 03:35 AM
