Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   nee to know what part need to replace (http://forum.appliancepartspros.com/washer-repair/299346-nee-know-what-part-need-replace.html)
wagra68 09-10-2011 04:34 PM
WHEN I PUT TO WORK MY WASHER IT START MOVING MY CLOTHES WITH OUT ADD ANY WATER ON THE TUB THEN WHEN IS GOING TO FINISH WITH THE CYCLES IT SPIN DRAIN THE WATER THEN BEFORE END IT ADD THE WATER TO THE TUB AND THEN STOP. I NEED TO KNOW WHAT IS COUSING THIS PROBLEM IN THE BEGINNING ONLY WAS DOING ONE I AWHILE NOW IS DOING ALL THE TIME.......:mad:
sidfink43 09-11-2011 06:09 PM
Your model number does not come up, so the generic answer is that the problem is with the control unit.
Also, please don't post in all caps, it is like you are shouting at us.
