| » hot water and fuse for washing machine |
Model Number: WISR309DGBWW Brand: GE Age: 1 - 5 years
Hello
I have a washing machine model (WISR309DGBWW). 1- the cold water flows in perfectly fine but the hot water doesn't why is this? 2- Is there an electric fuse in the hot water in the in the washer model (WISR309DGBWW) (that resists a strong electric shock) on the fuse and that's why the hot water doesn't want to flow in cause the fuse burned out which stops the electricity from letting the water in. 3-if the fuse burned out does it stop the water from flowing in the washer? 4-for my washing machine (WISR309DGBWW) can i place somthin small like a fuse or something else small in the washer that would make the washer heats the water in the washing machine? thanks Ads By Google Related Models |
There is no fuse here.
Switch the connectors on the hot and cold water valve assembly. If cold water flows and the hot water does not flow when you set the selector to hot, the water valve is not opening for hot and needs to be replaced. If hot water comes out when cold water is selected and cold water does not come out when hot water is selected the problem can be in the timer or the water selection switch.
__________________
thank you very much and i really appreciate your answer and help i have been searching for my problem for like a month anyways last question can i put something inside the washer like a spare part so the washer can heat its own water?
thank you again |
Hi sidfink43
My problem with the hot water happens to happen again with me but this time the hot water doesn't want to flow into the washer machine but when we got a bucket and directed the hot water's hose into it the hot water started to flow easily. Is there any solution for my problem thanks Chris James |
| Display Modes | |
| Washing machine will not fill with water | KimPyles | Washer Repair | 6 | 05-03-2011 01:33 PM |
| washing machine not stopping to take water in | Akram | Washer Repair | 1 | 09-23-2010 07:42 PM |
| Washing machine does not fill up with water | Eddiedean | Washer Repair | 1 | 01-29-2010 11:14 AM |
| washing machine won't spin the water out it | jgosch | Washer Repair | 1 | 05-10-2009 08:01 AM |
| My washing machine fills with water, but that's it | pejza | Washer Repair | 2 | 07-12-2008 01:47 PM |
