Discuss
Frigidare Washer drain pump problem
 in
Washer Repair
I am trying to repair a Frigidare WDM - l1 top loading washing machine. It fills and washes normally but
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidare Washer drain pump problem
  #1 (permalink)
Old 09-08-2011, 04:35 PM
Junior Member
guermo is on a distinguished road
Default Frigidare Washer drain pump problem
Model Number: wdm-l1   Brand: Frigidaire   Age: More than 10 years
I am trying to repair a Frigidare WDM - l1 top loading washing machine. It fills and washes normally but at the end of the wig wag cycle it stops and nothing happens. I suspect that this is when the drain cycle is supposed to start, but nothing happens. Then the machine trys to go into the spin cycle and some water is forced out of the drain hose, but some kind of clutch kicks it out of spin. The next thing that happens is that it blows the GFI that it is plugged into. If you reset the GFI nothing happens and it trys to go through spin again.
I have the motor and pump out of it, but can not figure out if the pump spins all the time the motor is running or if there is some kind of disconnect between the top (Pump end) and Bottom (pully end.) There is an electrical connection where the wiring harness plugs into the side of the motor and then a series of wires that go up to a electro - mechanical relay on the top of the motor. I have not figured out how to test that.
I cant figure out if the problem is in the timer or in the motor / pump actuator.
Thanks,
Bill
This machine is in a cabin and while it is old it has not been used hardly at all.
Ads By Google
Related Models
Frigidaire WDMA1 Frg(v11) / Washer
Frigidaire WDMF1 Frg(v12) / Washer
Frigidaire WDMH1 Frg(v13) / Washer
Frigidaire WDML1 Frg(v14) / Washer
Frigidaire WDML2 Frg(v13) / Washer
Frigidaire WDMW1 Frg(v15) / Washer
Frigidaire WDMW2 Frg(v14) / Washer
 WDP1W Washer
 WDP1W Washer
 WDP2B Washer
 WDP2W Washer
 WDP3B Washer
 WDP3G Washer
 WDP3G Washer
 WDP3N Washer
 WDP3R Washer
 WDP3S Washer
 WDP3T Washer
 WDP3U Washer
 WDP3W Washer
Frigidaire WDP632GER0 Wwh(v0) / Dishwasher
Whirlpool WDP68805
General Electric WDRR2500K0WW WASHER
General Electric WDRR2500K1WW WASHER
General Electric WDRR2500K2WW WASHER
General Electric WDRR2500K3WW WASHER
General Electric WDRR2500K4WW WASHER
Frigidaire WDSCL2 Frg(v1) / Washer
Frigidaire WDSCL3 Frg(v1) / Washer
Frigidaire WDSCL5 Frg(v1) / Top Loading Washer
Frigidaire WDSCL6 Frg(v2) / Top Load Washer
Frigidaire WDSCLL0 Frg(v4) / 27 " Washer
Frigidaire WDSCLL1 Frg(v5) / 27 " Washer
Frigidaire WDSCLL2 Frg(v2) / 27 " Washer
Frigidaire WDSCLW0 Frg(v3) / 27 " Washer
Frigidaire WDSCLW1 Frg(v4) / 27 " Washer
Frigidaire WDSCLW2 Frg(v1) / 27 " Washer
Frigidaire WDSCW2 Frg(v2) / Washer
Frigidaire WDSCW3 Frg(v2) / Washer
Frigidaire WDSCW4 Frg(v0) / Washer
Frigidaire WDSCW5 Frg(v2) / Top Loading Washer
Frigidaire WDSCW6 Frg(v1) / Top Load Washer
Frigidaire WDSDL2 Frg(v15) / Top Loading Washer
Frigidaire WDSDL3 Frg(v11) / Top Load Washer
Frigidaire WDSDLL0 Frg(v8) / 27 " Washer
Frigidaire WDSDLL1 Frg(v8) / 27 " Washer
Frigidaire WDSDLW0 Frg(v0) / 27 " Washer
Frigidaire WDSDLW1 Frg(v7) / 27 " Washer
Frigidaire WDSDW2 Frg(v16) / Top Loading Washer
Frigidaire WDSDW3 Frg(v10) / Top Load Washer
Frigidaire WDSFW0 Frg(v1) / Top Load Washer
Frigidaire WDSLL0 Frg(v2) / 27 " Washer
Frigidaire WDSLL1 Frg(v2) / 27 " Washer
Frigidaire WDSLW0 Frg(v1) / 27 " Washer
Frigidaire WDSLW1 Frg(v1) / 27 " Washer
General Electric WDSR110T5WW WASHER
General Electric WDSR2080D0CC Washer
General Electric WDSR2080D0WW Washer
General Electric WDSR2080D2CC Washer
General Electric WDSR2080D2WW Washer
General Electric WDSR2080D4WW Washer
General Electric WDSR2080D5CC Washer
General Electric WDSR2080D5WW Washer
General Electric WDSR2080D6WW Washer
General Electric WDSR2080D7WW Washer
General Electric WDSR2080D8WW Washer
General Electric WDSR2080DACC Washer
General Electric WDSR2080DAWW Washer
General Electric WDSR2080DBCC Washer
General Electric WDSR2080DBWW Washer
General Electric WDSR2080DCCC Washer
General Electric WDSR2080DCWW Washer
General Electric WDSR2080DDCC Washer
General Electric WDSR2080DDWW Washer
General Electric WDSR2080DECC Washer
General Electric WDSR2080DEWW Washer
General Electric WDSR2080DFWW Washer
General Electric WDSR2080G0CC Washer
General Electric WDSR2080G0WW Washer
General Electric WDSR2080G2CC Washer
General Electric WDSR2080G2WW Washer
General Electric WDSR2080G3CC WASHER
General Electric WDSR2080G3WW WASHER
General Electric WDSR2080G5CC WASHER
General Electric WDSR2080G5WW WASHER
General Electric WDSR2080G6CC WASHER
General Electric WDSR2080G6WW WASHER
General Electric WDSR2120J3WW WASHER
General Electric WDSR2120J5WW WASHER
General Electric WDSR2120J6WW WASHER
General Electric WDSR2120J7WW WASHER
General Electric WDSR2120J8WW WASHER
General Electric WDSR2120J9WW WASHER
General Electric WDSR4110T2AA Washer
General Electric WDSR4110T2WW Washer
General Electric WDSR4110T5AA Washer
General Electric WDSR4110T5WW Washer
General Electric WDSR4110T6AA Washer
General Electric WDSR4110T6WW Washer
General Electric WDSR4110T8AA Washer
General Electric WDSR4110T8WW Washer
General Electric WDSR4110TAAA Washer
General Electric WDSR4110TAWW Washer
General Electric WDSS4120A0WW Washer
Whirlpool WDT710PAYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDT710PAYB1 UNDERCOUNTER DISHWASHER
Whirlpool WDT710PAYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDT710PAYM1 UNDERCOUNTER DISHWASHER
Whirlpool WDT710PAYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDT710PAYW1 UNDERCOUNTER DISHWASHER
Whirlpool WDT770PAYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDT770PAYB1 UNDERCOUNTER DISHWASHER
Whirlpool WDT770PAYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDT770PAYM1 UNDERCOUNTER DISHWASHER
Whirlpool WDT770PAYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDT770PAYW1 UNDERCOUNTER DISHWASHER
Whirlpool WDT790SAYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDT790SAYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDT790SAYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDT790SLYB0 UNDERCOUNTER DISHWASHER
  #2 (permalink)
Old 09-10-2011, 06:47 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
This has the look of a very old Frigidaire, maybe even when they were made by GM
I suspect the pump is the issue, but if it has set idle in a cabin the wiring may be an issue.
I don't think you can get parts, and a nice used machine may be your better option.
__________________
  #3 (permalink)
Old 09-10-2011, 08:41 PM
Junior Member
Default
Thanks Sid.
I would be happy to get another one, but to remove this thing which is in a basement, the door, trim and jam to the laundry room has to come off and then the same thing for a bathroom door and then there is a set of steps to get it up to the main floor and several sets of steps to get it up to the street level and finally I am by myself. Next if the decision is made to replace the washer the dryer is also going to go. That is the main reason why we are trying to fix such an old machine - though it is like new.
I was just trying to figure out a way to tell which of the components it is that failed, and if the shaft that runs the pump is one piece all the way through the motor to the drive pully. The motor in the wigwag cycle runs fine and when I disassembled the pump, it was clear and looks new. The pump impeller is hooked directly to the motor shaft opposite the drive pulley and it feels like one piece. I guess the grand mistake I made was not to have checked the operation in the two cycles - regular and permanent press as I now understand that the pump may work on one quadrant of the timer but not in another. I am going to have to put the motor back in and try that.
Thanks again for your thoughts.
Bill
  #4 (permalink)
Old 09-11-2011, 05:40 AM
Senior Expert
APP Volunteer
Default
Well I can understand your need to repair rather than remove the machine from a difficult area.
The pump is really the prime suspect. If the cabin was unheated and subjected to freezing temperatures some water in the pump may have frozen and damged it.
I would suggest you put it back together, see if it works in other cycles and go from there.
Getting parts for this is going to be difficult, but there are parts suppliers for very old machines on the internet
Good luck, let us know what happens.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Tromm Washer Drain Pump... Imtiaz Washer Repair 1 01-26-2011 09:05 AM
Problem with my drain pump ??? alexandre1733 Dishwasher Repair 3 10-25-2010 07:15 AM
Frigidaire Drain Pump Problem? cuysan Dishwasher Repair 2 06-04-2010 04:46 AM
Top loader washer does not drain - pump problem? acurrier Washer Repair 1 01-04-2010 12:34 PM
New pump but washer will still not drain FredPam Washer Repair 5 08-29-2009 04:01 PM
