| » Frigidaire front loader leak |
Model Number: CRTF1240AS0 Brand: Frigidaire Age: 5 - 10 years
My Frigidaire CRTF1240AS0 front loading clothes washer developed a leak over the past year or so. I just started noticing water coming from under washer after we did laundry. I took the lower front panel off and found that the water was leaking from the tub seal or o-ring that goes around the outer tub. It looked like it would be too much of a chore to replace that so I checked the bolts for tightness and they were all fine. I basically ignored it and would just ocasionally just wipe up the water.
Flash forward to today when I noticed a LOT more water after two loads that were fairly large (a blanket in one and a load of towels in another). I decided to replace the tub seal. After attempting to remove the shock absorber level pins, I had to look for help on that. It sounds like my shocks are bad. I think that the washer has done more shaking since we started noticing the water. I read that the shocks could be causing the leaking as well. Enough with the back-story. Here are my questions: 1. Am I wrong to assume that on a heavy load, when the shocks are not absorbing the vibrations, the two peices of the tub flex and that's where my water is coming from? 2. I'm looking at ordering up a shock absorber kit, and the tub seal. I figure that if I'm going to go through the hassle of taking it apart, I might as well replace the tub seal (tub is already out of the washer). Is that going to cause me more heartburn/leak more if I replace it as well? 3. Is there anything else I should be doing maintenance wise on a 8+ year old frigidaire front loader while I have it in peices? Ads By Google Related Models |
I think you are doing the right things. Go ahead and replace the shocks and the seal. That should fix your problem, but you should know that these models are very prone to a rear bearing failure which is usually fatal
since it means replacing the rear part of the tub which is expensive. If you are even considering replacement, now is the time to do it.
__________________
Quote:
Kudos to appliancepartspros.com by the way. I ordered up the parts Thursday morning and had everything back up and running Friday night. They are easily my new favorite parts store. |
| Display Modes | |
| maytag neptune front loader leak | paulp937 | Washer Repair | 3 | 05-30-2011 05:59 PM |
| frigidaire front loader | caleno | Washer Repair | 3 | 11-14-2010 05:32 PM |
| Frigidaire front loader | seminole | Washer Repair | 2 | 07-19-2010 06:20 AM |
| Frigidaire Front Loader won't run | hguyette | Washer Repair | 3 | 06-29-2009 11:15 AM |
| frigidaire front loader | charles schaus | Washer Repair | 1 | 04-06-2009 07:04 PM |
