Tub seal seems to be leaking how much of a job to remove tub and replace tub seal.
For this dependable care washer, rather routine. Go to web site www.applianceaid.com for specific info. You will need the special spanner wrench available on this site.You will also need a steel rod to drive up and out the sleeve bearing on the tranny spindle housing.
