Discuss
Washer problem
 in
Washer Repair
When using the regular cycle, problem is in the final spin cycle. It won't completely empty the water out. Sometimes,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer problem
  #1 (permalink)
Old 09-07-2011, 12:58 AM
Junior Member
Max&Mimi is on a distinguished road
Unhappy Washer problem
Model Number: LRS7233BW2   Brand: Whirlpool   Age: More than 10 years
When using the regular cycle, problem is in the final spin cycle. It won't completely empty the water out. Sometimes, the level is completely full, other times, half empty, and yet other times, water is emptied out, but clothes are still extremely wet. Cycle timer is still operating, because the cycle will complete, just not spinning out the water. However, if I use the permanent press cycle, everything works great...no problems at the final spin cycle. Do you know if the part to correct this problem would be in the timer switch or the clutch, or possibly a different part, and which part it would be? The only way I can get the spin cycle to complete in the regular wash cycle is by either pressing in or holding out on the knob.
Ads By Google
Related Models
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
Maytag LRTD17A Ref - Top Mount
Maytag LRTD19A Ref - Top Mount
Maytag LRTD21A Ref - Top Mount
Maytag LRTD23A Ref - Top Mount
Maytag LRTS17A Ref - Top Mount
Maytag LRTS19A Ref - Top Mount
Maytag LRTW22A Ref - Top Mount/ I&W
  #2 (permalink)
Old 09-08-2011, 06:57 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It is almost certainly the timer, since it works in one other cycle. You should try replacing the timer, that should do it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer problem john womble Washer Repair 0 01-20-2011 07:47 PM
washer problem prcsofwales Washer Repair 1 10-25-2010 09:36 AM
How to fix washer simple looking problem with washer Woltato Washer Repair 1 09-20-2009 07:21 AM
washer problem resta Washer Repair 3 05-08-2009 01:58 PM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
