Discuss
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise
 in
Washer Repair
I put a load in the other day, a shirt got wrapped up and stuck. Now when I turn on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise
  #1 (permalink)
Old 11-28-2007, 07:13 PM
Scottmcc Scottmcc is offline
Junior Member
Scottmcc is on a distinguished road
Default Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise
Model Number: 110.26842691   Brand: Kenmore   Age: 1 - 5 years
I put a load in the other day, a shirt got wrapped up and stuck. Now when I turn on the washer on spin cycle, nothing happens. The washer makes a humming/grinding sound. When I start from the begining of a cycle it will fill with water and that's it. It won't agitiate, spin or drain. Did I burn out the motor? I didn't smell anything burning or an electrical smell when the shirt got wrapped up. The shirt was only wrapped up for about 10 minutes.. Is there a way to check the motor. Is there a limit switch? Thanks for your help..
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-28-2007, 09:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does it make any noises on wash or drain cycles?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-28-2007, 10:45 PM
Junior Member
Default Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Reply to Thr
Yes, it makes the same humming/grinding noise in all the cycles..
  #4 (permalink)
Old 11-28-2007, 10:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sound like the motor is gone.
Remove the cabinet. Remove the drain pump and the motor.
Check all wires to the motor.
Check the capacitor.
Turn the washer on and see if the motor runs.
- The part number for the motor capacitor AP3866194
- The part number for the motor AP2905451
__________________
  #5 (permalink)
Old 11-29-2007, 02:08 AM
Junior Member
Hey thanks.. I will try that tommorrow.. Is there a way that I Can test the capasitor or the motor?
  #6 (permalink)
Old 11-29-2007, 12:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can test the capacitor on continuity. It should be infinite and, after you switch probes around, it should be infinite again.
Test the motor as I described in the previous post.
__________________
  #7 (permalink)
Old 01-05-2008, 08:24 AM
michael walker michael walker is offline
Junior Member
michael walker is on a distinguished road
Smile help is on the way
Quote:
no my friend you just need a motor coupling that goes between the motor and transmission
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't complete cycle-grinding noise rebekah Washer Repair 2 12-13-2007 08:20 PM
Kenmore series 70, model 110 makes clunking noise? washerTed Washer Repair 1 11-18-2007 05:36 PM
RCA Washer will not spin or agitate huffmanrq Washer Repair 0 11-18-2007 09:22 AM
Kenmore 80-series washer skips spin time mac Washer Repair 1 08-14-2007 07:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
