| » dryer won't heat |
Model Number: dhdsr46eeoww Brand: GE Age: 1 - 5 years
here's the problem dryer will not heat what do i check and how do you take the dryer apart to get to the bad components this is unlike any dryer that i have fixed before so i need the best possible way to get to what needs replacing can you point me in the right direction to assist me in making this repair a snap.
Disconnect power from dryer. Then open the door of the dryer and remove the two screws pointing upward. Once done you should be able to remove the top. Then remove the two screws point forward. Once these screws are out the front should lean forward and lift up and move to the side. Then reach under the tub and unhook the belt. Then the tub should pull strait out. Once the tub is out you should see the heating element and it is the most likely cause for this. Normally you can see that the heater is broken. Note look good because most of the time it breaks near the holders. For more on this visit GE Dryer Not Heating Repair Guide
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
