Our Maytag LAT9605 filled normally and then began to agitate. However, it keep on filling and overfilled. It did not stop filling after the water reached the normal level. Any ideas on this ?? Also, I understand there are two different timers for this model. About a year ago I replaced the timer and since then, the cycle will not advance. We have to advance the timer manually to get the washer to change cycles. Is it possible I have a bad timer or the incorrect timer ?? Thanks for any help on this..
